February 18, 2023, 10:22 |
Bolted Joints between 3D printed Parts
MC
Rep Power: 5 |
Dear all,
I performed a series of FEM simulations considering a 3D printed frame made up of several components fabricated with additive manufacturing. For the analyses I considered their behaviour much similar to the one of the steel structures (aware of the uncertainties this procedure is causing). When I simulated the bolted connections between bodies, I simply assumed "bonded-type contact". I did not find in the literature any example dealing with frictional joints between AM parts, so I went for the simplest option. Do you have suggestions on papers I could read which deal with similar problems? In particular I am interested in the stiffness and damping of steel joints for 3D printed material, how they influence the connection and how I should take this into account in the FEM simulations. Moreover, it would be good to have an idea on how reliable is the approach I used (in terms of uncertainty and underestimation of the stress level). Thanks a lot for your help and suggestions |
Structural Dynamic Analysis to Find the Response of Individual parts in an Assembly d | SaiPrasad Chowdavaram | Structural Mechanics | 0 | July 21, 2022 08:21 |
[ICEM] How to create multiple parts properly in ICEM-CFD? | ElGrande | ANSYS Meshing & Geometry | 0 | March 4, 2021 03:43 |
[ICEM] Mesh shells assigned to wrong parts | philalama | ANSYS Meshing & Geometry | 2 | December 21, 2020 06:59 |
Generate Parts Using Named Selection | jonasohlsson | ANSYS | 1 | March 14, 2016 05:32 |
