Problem with L2 Norm of stress for a plate with circular hole |
September 28, 2022, 11:01 |
Yusuf Elbadry
Rep Power: 8 |
Hello!
I have having a problem with calculating the L2 Norm of stress and displacement. I am solving a plate with a circular hole using IGA. I am using an open-source package called NLIGA (written in MATLAB). I am solving the upper right quarter of the problem with symmetric BC on the left and bottom boundaries and tension on the right and upper boundaries. I calculated the Energy norm and it converges well (0.5*u'*K*u). But for calculating || u_app - u_ex ||_L2 and || sigma_h - sigma_ex ||_L2 The behavior is not expected at all and I tried to compare it with T.J.R Hughes's paper (2005). For the L2 norm of stress, for example, I tried calculating it at p=q=2 and p=q=3 and plotting it on log-log with "total number of elements" as the horizontal axis. I am expecting to see a line for each degree with a negative slope. What I got for each case is a line with a negative slope but somehow the L2 norm converges to a value! lets say 0.0508. So, both L2 norms at different polynomial degrees, reach the same value at the end. Is there any explanation for that?!!! |
Abnormal shear stress contour on a circular cylinder | Fengda | FLUENT | 0 | July 26, 2020 05:47 |
Free surface/open channel flow over a circular plate | mujahidbadshah | CFX | 1 | May 18, 2016 11:55 |
[blockMesh] circular plate mesh with cyclic | blackbow | OpenFOAM Meshing & Mesh Conversion | 0 | November 6, 2015 06:05 |
problem of the drag's convergence for a circular cylinder with a synthetic jet (udf) | bia | FLUENT | 0 | February 17, 2015 12:06 |
[GAMBIT] Making hundereds of small hole in a thin plate using Gambit | irfanlhr | ANSYS Meshing & Geometry | 2 | October 23, 2012 08:05 |
