August 2, 2022, 11:49 |
Changing structures over time
Daniel S Pereira
Rep Power: 4 |
Hello folks
this is my first post here, I hope I don't break any rules! I am a civil Engineer and M.SC. in structures Engineering and I model and design structures, mostly using FEM. Right now I am interested in the concept behind the static modeling of changing structures. Some cases are really simple, for instance: 1) If you load a structure then remove some part of it while keeping the same load, then the new moments, shear forces and strains can be easily obtained by simply ignoring the original structure. You load the new structure and that's it. 2) If you apply Load 1 on Structure 1, then add a structural element to it and finally apply a new Load 2, then the final state of forces and displacements is obtained by adding L1 on Structure 1 to L2 on structure 2. No big deal here. But what if after loading the structure, you add a new part and then remove an old one? |
October 7, 2022, 08:29 |
Daniel S Pereira
Rep Power: 4 |
I did, yes!
bash script for pseudo-parallel usage of reconstructPar | kwardle | OpenFOAM Post-Processing | 42 | May 8, 2024 00:17 |
courant number increases to rather large values | 6863523 | OpenFOAM Running, Solving & CFD | 22 | July 6, 2023 00:48 |
Slow calculation time on CFD server | killian153 | Hardware | 4 | July 27, 2021 08:28 |
Star cd es-ice solver error | ernarasimman | STAR-CD | 2 | September 12, 2014 01:01 |
same geometry,structured and unstructured mesh,different behaviour. | sharonyue | OpenFOAM Running, Solving & CFD | 13 | January 2, 2013 23:40 |
