Home > Forums > General Forums > Structural Mechanics
Physics problem; fea simulation help
Old   December 21, 2021, 06:32
Talking Physics problem; fea simulation help
Richard Wales
cat_wales_dog is on a distinguished road
Hi Everyone!
I made a simple machine that vibrates some plastic container inside a cage. The reciprocating motion is due to the rotation of a motor at a constant revolution of 110 rpm. I wanted to make an FEA study on the structural frame using multi-axial fatigue analysis; however, I'm confused as to what load and constraint should be included and shouldn't. I was able to determine the maximum torque required by the motor using Autodesk Dynamic Analysis. It gave me an answer of 3.1 x 10^6 N.mm. The forces on each joint are quite hard to determine because the dynamic analysis doesn't allow redundant joints. I would like to seek help on how could I determine the loads (forces/moments) as well as the proper constraints; may it be using software or hand calculations.
I am attaching all the related images. Any help would be appreciated. Thank you.
cat_wales_dog is offline   Reply With Quote
Problem with restart in FSI unsteady simulation david_mocholi SU2 1 June 24, 2023 07:06
Convergence Problem - Transient Simulation gemxx Main CFD Forum 0 July 15, 2018 10:36
Problem with multi stage compressor simulation. Geant18 CFX 0 June 22, 2018 06:03
Problem with wall surface reaction simulation in Fluent suren1992 CFD Freelancers 1 June 7, 2018 05:14
Problem in initializing transient simulation with a finer mesh sidd CFX 8 April 29, 2016 03:25
