Home > Forums > General Forums > Structural Mechanics
Abaqus is unable to locate a C++ compiler
Old   November 18, 2021, 19:11
Default Abaqus is unable to locate a C++ compiler
TheEngineer98 is on a distinguished road
Hello everyone,
i need to use uMat and user subroutines in Abaqus for my masters thesis.
I installed Abaqus 2020, Visual Studio 2019, Intel oneApi Base Toolkit and Intel oneApi HPC Toolkit (in this exact order). After successfully linking the Fortran Compiler (Intel Fortran Compiler 2021.4) with VS19 (setting all the path variables and editing the abaqus2020.bat and the abaqus_v6.env) i started Abaqus Command (as admin) and used the command: abaqus verify -user .. it PASSED right away.
My main problem is the following:
If i plug in "abaqus info=system" everything is fine except the C++ Compiler.
C++ Compiler: Unalbe to locate or determine the version of a C++ compiler on this system. If a C++ compiler is installed on this system, please load vcvars64.bat file before running Abaqus
I tried every possible solution i could imagine:
- different versions of VS
- different OS
- different Processor
- calling the vcvars64.bat in abaqus2020.bat
- Installing third party c++ compilers (MinGW)
I just can't find a solution to this issue. I hope someone here can help me with this problem.
My current setup (if that helps):
Processor: AMD Ryzen 5 3600
RAM: 32 GB DDR4 3200
Graphics: MSI NVidea Geforce GTX 1660 Ti
OS: Windows 11
Linker Version: Microsoft Incremental Linker Version 14.29.30137.0
Fortran Compiler: Intel Fortran Compiler 2021.4
MPI MS-MPI 9.0.12497.11
(This is my first post in this forum - please don't be too hard on me)
I am grateful for any help - Thank you
TheEngineer98 is offline   Reply With Quote
Old   May 16, 2024, 08:20
nameuser is on a distinguished road
Have you solved the problem yet?
I got exactly the same issues and don't know what to do anymore...
nameuser is offline   Reply With Quote
Old   June 22, 2024, 16:05
Martin_Sz's Avatar
Marcin
Martin_Sz is on a distinguished road
Try these possibilities in the link below
https://howtooansys.blogspot.com/2024/06/abaqus-is-unable-to-locate-c-compiler.html
Quick Tips and Tricks, Tutorials FLuent/ CFX (CFD)
Martin_Sz is offline   Reply With Quote
[OpenFOAM.com] Installing on Ubuntu 18.04 samiam1000 OpenFOAM Installation 11 April 27, 2020 01:01
[OpenFOAM.com] Issue configuring ./makeParaView - Ubuntu 16.04 bjdarrer OpenFOAM Installation 2 April 20, 2020 14:50
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 19:56
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 14:43
[Commercial meshers] ST_Malloc: out of memory.malloc_storage: unable to malloc Velocity SA, cfdproject OpenFOAM Meshing & Mesh Conversion 0 April 14, 2009 16:45
