Home > Forums > General Forums > Structural Mechanics
Damping in Ansys
Old   October 13, 2021, 04:01
Default Damping in Ansys
SaiPrasad Chowdavaram's Avatar
SaiPrasad
SaiPrasad Chowdavaram is on a distinguished road
Hi all ...
I have a doubt .
I am working as FEA engineer working on Vibration problems . While performing Transient vibrational analysis there is an input that need to be provided in analysis settings of Ansys which is Damping . May I know
1. what is the percentage of damping that is to be used .
2. Is there any hard and fast rule to have specified damping percentage like 2% 3% ... If yes how to justify that.. how to calculate it theoretically .
Please help me in sorting out this doubt .
Thanks all in advance .
Thanks & Regards
Saiprasadchowdavaram
SaiPrasad Chowdavaram is offline   Reply With Quote
Old   October 13, 2021, 12:11
karachun's Avatar
karachun is on a distinguished road
Damping is a complex physical phenomenon. It depends both on material properties and more on the type of joints used in structure. For example riveted structures have more damping than welded.
There are no simple and universal methods to calculate damping. Usually damping is determined by experiment. There is a general rule of thumb to use 2-3%, without any theoretical grounding.
Try to check some codes for your structure. For example codes for seismic calculations of Nuclear power plants contain damping values for typical nuclear plant components like piping and engineers can use these damping values for their calculations.
karachun is offline   Reply With Quote
Old   October 14, 2021, 03:06
SaiPrasad
Thankyou .
Please share more info if u have any .
Old   October 14, 2021, 07:06
karachun's Avatar
I mentioned enough information.
Selection of adequate damping is up to you.
ANSYS licenses gsamsa ANSYS 13 July 5, 2024 20:46
FSI simulation in ansys cfx Arash67.m CFX 1 September 29, 2017 10:52
ANSYS ACT ACoustics and Diffuse sound (TRansmission loss) Many ANSYS 0 February 19, 2016 08:08
Fluid structure interaction jnattia Main CFD Forum 25 May 21, 2015 10:16
Ansys workbench problem Jonny6001 ANSYS 2 September 30, 2010 13:59
