Home > Forums > General Forums > Structural Mechanics
Conducting crack progration on sample with a hole in the middle of the crack path
Old   January 29, 2021, 04:23
Question Conducting crack progration on sample with a hole in the middle of the crack path
mazayiz is on a distinguished road
Hello
I am trying to simulate a 2D brittle material undergoing a tensile test. I am using xfem crack growth to simulate this failure. However I have introduced a hole in the material in line with its crack path. I use quad advancing front meshing and run multiple tests with finer and finer mesh to try to get a convergence of the results. However when the sample's crack growth reaches the defect, the sample no longer complete fails. Increasing the mesh has the crack reach the opposite end of the sample but not completely fail. The resulting step time never changes and the calculations of the sample never move past a certain point even after 10,000 increments and a force is still acting on the sample.
Any suggestions as to what can be done to induce complete failure of the sample? Is it possible that the element deletion is not functioning properly after the crack reaches the defect? Is there any examples of abaqus being used to direct crack growth to a defect and see the effect of the hole on the crack? I have not been able to find any examples of this type of case and instead the crack path is usually directed directed across a sample without any defect in its path.
I have also linked some images to show some of the things of what has happened.
https://i.imgur.com/dEwoMlq.jpg
https://i.imgur.com/AkEDW1H.jpg
https://i.imgur.com/cWpdLoM.jpg
Thank you
mazayiz is offline   Reply With Quote
abaqus, crack growth, defect, hole, xfem
heat conducting in a solid domain Rogerio Fernandes Brito Fidelity CFD 0 March 18, 2008 18:24
heat conducting in a solid domain Rogerio Fernandes Brito Phoenics 0 March 18, 2008 18:23
heat conducting in a solid domain Rogerio Fernandes Brito Siemens 0 March 18, 2008 18:23
heat conducting in a solid domain Rogerio Fernandes Brito CFX 0 March 18, 2008 18:20
CAE program for heat conducting Rogerio Fernandes Brito FLUENT 0 February 3, 2008 12:22
