Home > Forums > General Forums > Structural Mechanics
Meshing complex small high curvature geoemtries
Old   March 10, 2020, 13:30
Default Meshing complex small high curvature geoemtries
HS
amsys is on a distinguished road
I want to do a fluid-structural analysis which includes the attached geometry for the structural side of the analysis in ANSYS. What would be the best way to mesh such a complex geometry? I have tried ANSYS meshing but it keeps failing..
Thanks.
amsys is offline   Reply With Quote
Old   March 10, 2020, 21:07
Svetlana Tkachenko
Svetlana is on a distinguished road
What error message do you get with ANSYS Meshing?
Svetlana is offline   Reply With Quote
Old   March 11, 2020, 06:17
HS
The error is: "Meshing state: Failed mesh" where 99% of the geometry is highlighted as failed.
Old   March 12, 2020, 07:57
karachun's Avatar
karachun is on a distinguished road
Determine smallest particle size and use this size divided by 10 as initial mesh size.
Or check all particles one-by-one. Determine individual particle size -> apply individual sizing to selected particle -> repeat.
You can right click on body and use option “Create Mesh on selected bodies” to mesh particles individual.
karachun is offline   Reply With Quote
structured mesh
[ICEM] Meshing of fluid and solid zone of complex structure through OCTREE Nils_H ANSYS Meshing & Geometry 8 February 21, 2020 17:34
Meshing in a complex geometry Jay_upd Mesh Generation & Pre-Processing 0 February 20, 2015 11:16
[ANSYS Meshing] Complex terrain meshing egge24 ANSYS Meshing & Geometry 0 November 5, 2014 21:05
[Workbench] High Cambered Aerofoil Meshing Problem (Workbench) elebelly ANSYS Meshing & Geometry 11 February 16, 2014 11:04
[GAMBIT] meshing in GAMBIT, a flow through a pipe having complex inflow geometry mazhar1613 ANSYS Meshing & Geometry 1 January 12, 2012 00:18
