Home > Forums > General Forums > Structural Mechanics
Workbench Contact Element
Old   October 7, 2019, 13:46
Unhappy Workbench Contact Element
Suleyman41 is on a distinguished road
What is correspond workbench contact type, mechanical APDL Contact type 48.
In workbench, I select frictional contact but i don't know another specification.
Suleyman41 is offline   Reply With Quote
Old   October 9, 2019, 09:04
Gweher's Avatar
Gwenael H.
Gweher will become famous soon enough
Depending on your problem definition WB is going to "automatically" choose the "best" contact element based on several parameters. You can use the advanced option to choose between augmented lagrange, MPC, etc which will affect the element contact type.
But in order to have full control you need to add a command snippet under the contact and change the contact type using the APDL command:
et,cid,176 !change element type to 176 -> change it to the contact element reference you need
Have fun
Gweher is offline   Reply With Quote
conta48, contact, workbench
[Gmsh] 3D Mesh conversion from gmsh-2.5.0 to OpenFOAM Ancioi OpenFOAM Meshing & Mesh Conversion 17 January 9, 2019 00:50
Identifying Markers in a CGNS Mesh tjim SU2 3 October 12, 2018 02:21
[Other] Mesh Importing Problem cuteapathy ANSYS Meshing & Geometry 2 June 24, 2017 06:29
FLUENT installation on UBUNTU 12.04 (LTS) teymourj FLUENT 2 March 1, 2017 23:24
Ansys Workbench contact problem! JoelHenrik ANSYS 1 October 1, 2010 15:57
