Home > Forums > General Forums > Structural Mechanics
Heat Load Distribution for ABAQUS/CAE
Old   August 7, 2019, 12:56
Default Heat Load Distribution for ABAQUS/CAE
Jonah Duran
JonahD is on a distinguished road
In Abaqus, I am trying to simulate a heat flux on a graphite rod with two flat faces and three curved surfaces.*The heat flux upon the flat surfaces is uniform in order to simulate a head on plasma.*The curved surfaces should have a higher heat flux magnitude closest to the flat faces. This combination should simulate a heat flux with incoming vector that is normal to the flat surface.*Heat flux should therefore fall off as you approach the center of the curved surfaces. The several methods I have tried are not behaving as expected. Attached is a photo of what I believe the heat flux should look like.*What should the load distribution analytical field be defined as for the curved surfaces?
https://imgur.com/a/Atxspn7
JonahD is offline   Reply With Quote
abaqus, thermal analysis
UDF about the heat source of the space distribution? wpdeng Fluent UDF and Scheme Programming 0 March 5, 2018 09:46
Cfd to ansys thermal to ansys structural interface ssixr ANSYS 17 July 31, 2015 16:18
Convective heat loss out of a solar receiver construction Lionel Trébuchon CFX 10 April 6, 2014 21:25
heat flux distribution gtheo CFX 2 April 27, 2011 04:36
Convective / Conductive Heat Transfer in Hypersonic flows enigma Main CFD Forum 2 November 1, 2009 23:53
