Home > Forums > General Forums > Structural Mechanics
Modelling expansion of balloon
Old   May 31, 2019, 20:38
Default Modelling expansion of balloon
Oli
OliScott is on a distinguished road
Dear all,
I want to use the solid mechanics tools in Openfoam Extend 4.0 to model a balloon expanding to determine how to make our device. The balloon has water either side of it - as the water outside is drawn back the balloon expands and the water inside is drawn in, and vice versa. If the balloon is too thin it breaks as the water is being drawn in. Neither do we want it too thick for various reasons. Hence I want to determine the stress/strain in this balloon to determine the material and thickness we need to make for it to work.
I need to model the point when the balloon is being expanded, drawing fluid inside. Can anyone give me any advice on how to setup this case please? Is it possible to just model the rubber balloon itself? If so is the elasticNonLinTLSolidFoam solver most appropriate? Or is it necessary to include the fluid in the simulation?
Many thanks!
OliScott is offline   Reply With Quote
Old   June 3, 2019, 05:48
karachun's Avatar
karachun is on a distinguished road
Pressure load is enough.
You should be familiar with hyperelastic material models and know parameters of your rubber. You can search on databases like Matweb.
https://www.academia.edu/32416590/An...stic_Materials
https://caeai.com/blog/tips-tricks-f...stomers-part-1
https://caeai.com/blog/tips-tricks-f...stomers-part-2
karachun is offline   Reply With Quote
elasticity, openfoam, strain, stress
Modelling an hot-air balloon ThatGuy Siemens 1 March 9, 2022 01:36
[blockMesh] Create internal faces as patch in blockMesh m.delta68 OpenFOAM Meshing & Mesh Conversion 14 July 12, 2018 15:43
Modelling wall stresses in a balloon kiwi.kczt ANSYS 1 March 19, 2016 19:16
Ammonia-liquid modelling. Problem with thermal expansion coefficient. zhekka FLUENT 0 February 9, 2010 16:06
Modelling Expansion valve/various pressure domains Rehan FLUENT 0 March 24, 2006 08:59
