Mesh of a welding seam end for structural analysis |
December 3, 2018, 10:57 |
Domi
Rep Power: 11 |
Hello everybody,
I´m not an expert in structural simulation and analysis, but I´m familiar with the basics in the common situation anisotropic, elastic and linear. For an easy geometry I´m interested in the stress analysis of let´s say two 5 mm thick welded aluminum sheets. I use the effective notch stress approach. For this, I remove material whit a radius of 1 mm in the area at the root of the welding seam. But how could I model/ mesh the end of the welding seams? Since it´s not a "closed" welding seam, I have to model it´s ends without getting singularities. I hope the situation is clear: There is a vertical and horizontal plate and the blue wedge represents the welding seam. You can see the U-shape notch, but as there is a right angle, I achieve singularities and I want to avoid this. Thanks a lot in advance. kr macRC |
December 3, 2018, 12:33 |
Domi
Rep Power: 11 |
I got a new results, please have a look on model and mesh of the welding seam attached. I don´t know if itis the correct approach, "opening the notch and add rounds". But at least the singularity could be reduced ... What do you think? Is it sufficient for a serious failure analysis? It´s just a steady load. I´m looking forward to your responses. kr macRC |
December 4, 2018, 07:27 |
Rep Power: 12 |
I would make plate model, calculate forces on weld and compare it (forces/moments, not stress - this is crucial!) with allowable values from standards/structural codes, like Eurocode 3 or ASME.
https://nptel.ac.in/courses/112105125/pdf/mod10les4.pdf |
Wind turbine simulation | Saturn | CFX | 60 | July 17, 2024 06:45 |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 06:21 |
Simulation of a single bubble with a VOF-method | Suzzn | CFX | 21 | January 29, 2018 01:58 |
Question about adaptive timestepping | Guille1811 | CFX | 25 | November 12, 2017 18:38 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 02:27 |
