Home > Forums > General Forums > Structural Mechanics
APDL Nonlinear Combin214 doesn't go beyond the first dynamic coefficient value
Old   October 26, 2018, 17:33
Default APDL Nonlinear Combin214 doesn't go beyond the first dynamic coefficient value
Alistair Robin
h1ch9m is on a distinguished road
Hi everybody
I am trying to make a comparison between the response of a linear and nonlinear squeeze film damper under a periodic force using a Combin214 element.
The script of the nonlinear case reads the dynamic coefficients values from external files, with Eccent and Theta as primary variables, whereas the linear case uses only one value for each parameter (Kxx,Kyy,Cxx and Cyy).
The problem I am facing : the nonlinear scripts use only the first value even if the movement goes beyond the rage of the table, which makes the two models have the same behavior.
I am suspecting a problem with the space reference but I couldn't fix it. The coefficient tables are Eccent & Theta variable based, whereas the calculations are based on the x y position of the mass.
Attached is the script (please remove the *txt extension) and the dynamic coefficient files.
File Type: txt Kxx2RTheta.txt (167 Bytes, 3 views)
File Type: txt Kyy2RTheta.txt (167 Bytes, 3 views)
File Type: txt Cxx2RTheta.txt (205 Bytes, 3 views)
File Type: txt Cyy2RTheta.txt (205 Bytes, 3 views)
h1ch9m is offline   Reply With Quote
combin214, eccent, nonlinear, squeeze_film_damper, theta
Heat transfer coefficient - what is waht Stan FLUENT 28 December 29, 2021 17:29
pls. help : life-drag coefficient in dynamic mesh loogtaan FLUENT 5 December 20, 2007 21:54
Single Bubble Gerrit Senger CFX 4 March 12, 2007 17:29
Dynamic similarity and coefficient KB Main CFD Forum 0 January 7, 2007 00:58
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 13:02
