APDL Programming buckling FEA C Section Cold Formed Steel |
October 23, 2018, 03:37 |
Tanmay
Rep Power: 8 |
I am facing issues with my program. Listed below. This is form my masters project. Also in what way can I connect the filleted surfaces shown in fig by a weld or just load or stress transfer connection. fini /clear /title,C160T2B70-1L /prep7 et,1,shell181 r,1,2 mp,ex,1,1.85e5 mp,nuxy,1,0.3 type,1 mat,1 real,1 k,1,69,19,0 k,2,69,0,0 k,3,0,0,0 k,4,0,159,0 k,5,69,159,0 k,6,69,139,0 k,7,0,0,2500 k,8,71,19,0 k,9,71,0,0 k,10,139,0,0 k,11,139,159,0 k,12,71,159,0 k,13,71,139,0 k,14,139,0,2500 l,1,2 l,2,3 l,3,4 l,4,5 l,5,6 l,3,7 l,8,9 l,9,10 l,10,11 l,11,12 l,12,13 l,10,14 adrag,1,2,3,4,5,,6,,,,,, adrag,7,8,9,10,11,,12,,,,,, afillt,1,2,4 afillt,13,3,4 afillt,14,4,4 afillt,15,5,4 afillt,6,7,4 afillt,17,8,4 afillt,18,9,4 afillt,19,10,4 local,11,1,0,19.5,20,,,90 k,57,5,0 k,58,5,90 k,59,5,180 k,60,5,270 a,57,58,59,60 asba,3,10 local,12,1,0,138.5,20,,,90 k,61,5,0 k,62,5,90 k,63,5,180 k,64,5,270 a,61,62,63,64 asba,19,3 local,13,1,0,138.5,2480,,,90 k,65,5,0 k,66,5,90 k,67,5,180 k,68,5,270 a,65,66,67,68 asba,10,3 local,14,1,0,19.5,2480,,,90 k,69,5,0 k,70,5,90 k,71,5,180 k,72,5,270 a,69,70,71,72 asba,19,3 local,15,1,139,19.5,20,,,90 k,73,5,0 k,74,5,90 k,75,5,180 k,76,5,270 a,73,74,75,76 asba,8,3 local,16,1,139,138.5,20,,,90 k,77,5,0 k,78,5,90 k,79,5,180 k,80,5,270 a,77,78,79,80 asba,19,3 local,17,1,139,138.5,2480,,,90 k,81,5,0 k,82,5,90 k,83,5,180 k,84,5,270 a,81,82,83,84 asba,8,3 local,18,1,139,19.5,2480,,,90 k,85,5,0 k,86,5,90 k,87,5,180 k,88,5,270 a,85,86,87,88 asba,19,3 csys,0 esize,5 amesh,all,,, allsel lsel,s,,,11 lsel,a,,,19 lsel,a,,,20 lsel,a,,,21 nsll,s,1 d,all,all,0 lsel,s,,,22 lsel,a,,,24 lsel,a,,,26 lsel,a,,,27 nsll,s,1 d,all,all,0 lsel,s,,,28 lsel,a,,,30 lsel,a,,,32 lsel,a,,,33 nsll,s,1 d,all,all,0 lsel,s,,,67 lsel,a,,,68 lsel,a,,,70 lsel,a,,,71 nsll,s,1 d,all,all,0 lsel,s,,,79 lsel,a,,,80 lsel,a,,,81 lsel,a,,,82 nsll,s,1 d,all,all,0 lsel,s,,,75 lsel,a,,,76 lsel,a,,,77 lsel,a,,,78 nsll,s,1 d,all,all,0 lsel,s,,,83 lsel,a,,,84 lsel,a,,,85 lsel,a,,,86 nsll,s,1 d,all,all,0 lsel,s,,,87 lsel,a,,,88 lsel,a,,,89 lsel,a,,,90 nsll,s,1 d,all,all,0 nsel,s,loc,x,4,64 nsel,r,loc,y,0,0 nplot nsel,r,loc,z,0,50 cm,N1,node cmsel,s,N1 d,all,uy,0 allsel nsel,s,loc,x,4,64 nsel,r,loc,y,0,0 nplot nsel,r,loc,z,2450,2500 cm,N2,node cmsel,s,N2 d,all,uy,0 allsel nsel,s,loc,x,0,0 nsel,r,loc,y,0,158 nplot nsel,r,loc,z,0,50 cm,N3,node cmsel,s,N3 d,all,ux,0 allsel nsel,s,loc,x,0,0 nsel,r,loc,y,0,158 nplot nsel,r,loc,z,2450,2500 cm,N4,node cmsel,s,N4 d,all,ux,0 allsel nsel,s,loc,x,0,0 nsel,r,loc,y,0,158 nplot nsel,r,loc,z,0,50 cm,N5,node cmsel,s,N5 d,all,uY,0 allsel nsel,s,loc,x,0,0 nsel,r,loc,y,0,158 nplot nsel,r,loc,z,2450,2500 cm,N6,node cmsel,s,N6 d,all,uY,0 allsel nsel,s,loc,x,4,64 nsel,r,loc,y,158,158 nplot nsel,r,loc,z,849,851 cm,N7,node cmsel,s,N7,node f,N7,fy,-0.01925 allsel nsel,s,loc,x,4,64 nsel,r,loc,y,158,158 nplot nsel,r,loc,z,1649,1651 cm,N8,node cmsel,s,N8,node f,N8,fy,-0.01925 allsel nsel,s,loc,x,74,136 nsel,r,loc,y,0,0 nplot nsel,r,loc,z,0,50 cm,N9,node cmsel,s,N9 d,all,uy,0 allsel nsel,s,loc,x,74,136 nsel,r,loc,y,0,0 nplot nsel,r,loc,z,2450,2500 cm,N10,node cmsel,s,N10 d,all,uy,0 allsel nsel,s,loc,x,139,139 nsel,r,loc,y,0,158 nplot nsel,r,loc,z,0,50 cm,N11,node cmsel,s,N11 d,all,ux,0 allsel nsel,s,loc,x,139,139 nsel,r,loc,y,0,158 nplot nsel,r,loc,z,2450,2500 cm,N12,node cmsel,s,N12 d,all,ux,0 allsel nsel,s,loc,x,139,139 nsel,r,loc,y,0,158 nplot nsel,r,loc,z,0,50 cm,N13,node cmsel,s,N13 d,all,uY,0 allsel nsel,s,loc,x,139,139 nsel,r,loc,y,0,158 nplot nsel,r,loc,z,2450,2500 cm,N14,node cmsel,s,N14 d,all,uY,0 allsel nsel,s,loc,x,74,136 nsel,r,loc,y,158,158 nplot nsel,r,loc,z,849,851 cm,N15,node cmsel,s,N15,node f,N7,fy,-0.01925 allsel nsel,s,loc,x,74,136 nsel,r,loc,y,158,158 nplot nsel,r,loc,z,1649,1651 cm,N16,node cmsel,s,N16,node f,N8,fy,-0.01925 allsel /SOLU PSTRES,ON SOLVE FINISH /SOLU ANTYPE,BUCKLE OUTRES,ALL,ALL BUCOPT,LANB,30 SOLVE FINISH /SOLU EXPASS,ON MXPAND,30,,,YES OUTRES,ALL,ALL SOLVE FINISH |
November 15, 2018, 09:31 |
Vlad
Rep Power: 8 |
Look for command CP. Defines a set of coupled degrees of freedom.
November 15, 2018, 09:56 |
Tanmay
Rep Power: 8 |
hey thanks for the reply
could help me in placing and syntax of command |
November 16, 2018, 04:31 |
Vlad
Rep Power: 8 |
For example in your model.
ASEL,S,,,16 NSLA,S,1 CM,ND_1,NODE ASEL,S,,,20 NSLA,S,1 CM,ND_2,NODE CMSEL,S,ND_1 CMSEL,A,ND_2 CP,ND_1,ALL,ALL |
November 16, 2018, 05:35 |
Tanmay
Rep Power: 8 |
thanks a lot
this should help |
November 22, 2018, 06:05 |
Tanmay
Rep Power: 8 |
how to solve the element shape issue
buckling, c section, cold formed steel |
Buckling analysis with ansys MECHANICAL APDL | deepthistephen | ANSYS | 1 | December 30, 2018 03:45 |
Identifying Markers in a CGNS Mesh | tjim | SU2 | 3 | October 12, 2018 02:21 |
[Commercial meshers] converting Fluent mesh to openfoam standard mesh | deepesh | OpenFOAM Meshing & Mesh Conversion | 31 | March 29, 2017 06:59 |
dsmcInitialise - dsmcFoam | archymedes | OpenFOAM Pre-Processing | 94 | July 15, 2016 17:14 |
[Other] How to create an MRF zone ? | aminem | OpenFOAM Meshing & Mesh Conversion | 2 | December 8, 2014 11:45 |
