Home > Forums > General Forums > Structural Mechanics
Deformations in a Coordinate System that rotates (moves) with the solid body
Old   September 7, 2018, 14:58
Question Deformations in a Coordinate System that rotates (moves) with the solid body
Dmitry
Pumpov is on a distinguished road
Hello all.
Suupose, we have such a problem. A disk oscillates, in a tilt way, around axis that belongs to a diameter of a disk. Due to some limited stiffness of a disk material, the surface of the disk may deform, though it could be submicrons, let's say.
And the task is to find the deflection of the surface of the disk. It might be harmonic analysis or, maybe, explicit dynamics!? (depends...)
For that purpose it would be convenient to see deformations in a coordinate system that moves together with the disk as with the absolute rigid body.
How that may be done in Ansys WB? Some Commands needed?
Pumpov is offline   Reply With Quote
Old   September 7, 2018, 15:50
Mrt23 is on a distinguished road
You can create local (or “session”) coordinate systems in the Visualization module for postprocessing purposes: field output results can be transformed to a specified user-defined coordinate system. These user-defined coordinate systems can be fixed in space or move with specified nodes as the model deforms. Session coordinate systems persist for the duration of your session only and are available only for a single output database; however, you can save session coordinate systems to their associated output database file for use in subsequent Abaqus sessions.
Mrt23 is offline   Reply With Quote
Old   September 8, 2018, 13:27
Dmitry
Originally Posted by Mrt23 View Post
You can create local (or “session”) coordinate systems in the Visualization module for postprocessing purposes: ... for use in subsequent Abaqus sessions.
I'm sorry. I'm not working in Abaqus, but Ansys Workbench, or may try Classical Ansys (if it would be needed to).
What about their capacities, abilities?
Old   September 10, 2018, 00:36
what does say ansys post_processor user guide say about these thing?
you can try another one like Meta or Hyperview.
Old   September 10, 2018, 09:00
Dmitry
Once, I got an advice to see that link:
http://www.padtinc.com/blog/the-focu...sys-mechanical
moving coordinate system
[ICEM] How to draw a 2D surface to a solid 3D Body NikoLee ANSYS Meshing & Geometry 2 November 8, 2016 10:24
Defining a moist body (Solid body containing moisture) arnidhin91@gmail.com FLUENT 0 October 15, 2016 13:07
Error - Solar absorber - Solar Thermal Radiation MichaelK CFX 12 September 1, 2016 06:15
OpenFoam 3.0.x Moving Solid Body Through Mesh im_lenny OpenFOAM Running, Solving & CFD 1 March 1, 2016 11:27
How can I fix a local coordinate system to the inlet phys-zephyr STAR-CCM+ 3 May 8, 2014 06:46
