ANSYS APDL - Loads and constrains with different direction |
F.L.
Rep Power: 0 ![]() |
Hello everyone,
I'm studying the deformation of a half loaded cylinder with tangential forces on the sides. I want to put constraints in Y direction and tangential forces on all sides. I can't find the correct solution for the bases because the command F is in the absolute coordinate system (X-Y-Z) and I used NROTAT to have tangential forces, but in this way also the constraints are rotated in tangential direction. In the attachments there are example of the problem. How can I get the right solution? Thanks for your help. |
apdl, cylinder, direction load, mechanical |
