Home > Forums > General Forums > Structural Mechanics
Ansys engineering data source problem
Old   April 15, 2018, 04:31
Default Ansys engineering data source problem
Tashefa S
Tashefa S is on a distinguished road
I've been trying to use Explicit Dynamics in ANSYS workbench and the engineering data sources window says no data. Can anyone please help me with this issue?
Tashefa S is offline   Reply With Quote
Old   April 26, 2018, 06:28
siw
Stuart
siw will become famous soon enough
You either need to select a suitable material from the Engineering Data materials library (there is a list of general non-linear materials and explicit materials) or you need to construct your own suitable material in Engineering Data. Then after refreshing your explicit dynamics analysis system you select the materials to the appropriate geometry parts in the Mechanical / Explicit STR outline tree.
Post an image of what you are seeing that gives the problem.
siw is offline   Reply With Quote
ansys 15 workbench, engineering data source, explicit dynamics, problems
[OpenFOAM] How to get the coordinates of velocity data at all cells and at all times vidyadhar ParaView 9 May 20, 2020 21:06
CFD by anderson, chp 10.... supersonic flow over flat plate varunjain89 Main CFD Forum 18 May 11, 2018 08:31
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 Seroga OpenFOAM Community Contributions 9 June 12, 2015 18:18
[swak4Foam] funkySetFields compilation error tayo OpenFOAM Community Contributions 39 December 3, 2012 06:18
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 02:24
