Home > Forums > General Forums > Structural Mechanics
Gradient surface (*volume*) load on surface
Old   January 19, 2018, 09:24
Default Gradient surface (*volume*) load on surface
Manos Adams
adamomanos is on a distinguished road
Hello to everyone!
I am new to this forum so please pardon me if this topic is already solved. As you can see in the picture below, I have a steel plate, upon which a HEA300 is sit. I'm working on an APDL environment. The plate is a shell63 (too old I know ) and what I'd like to do, when I am on /SOLU processors, is to apply a gradient surface load along a portion of this area, to simulate the distributed triangular-shape stress. I've tried SFGRAD command in several ways, but it seems that it does not work properly when it regards "volume-shaped" surface loads. So, next step was to deploy a DO loop, so that I can pass through every node of the meshed area, and apply the appropriate load. (You can see that DO loop in the image, as well). BUT, as you will see, the DO loop is strangely repeated only ONCE and then appears no warnings or errors, assigning the ultimate values of the scalar parameters to them and finally, applying one surface load on the first line of nodes. What shall I do? Any suggestions?
adamomanos is offline   Reply With Quote
apdl, do loop, sfgrad, stress analysis
Objective function gradient verification: surface vs volume integral formulation Evgeniy SU2 7 February 27, 2018 07:38
question regarding LES of pipe flow - pimpleFoam Dan1788 OpenFOAM Running, Solving & CFD 37 December 26, 2017 15:42
Periodic flow using Cyclic - comparison with Fluent nusivares OpenFOAM Running, Solving & CFD 30 December 12, 2017 06:35
Wind load on surface => Turbulence modelling pz1337 CFX 3 March 7, 2012 18:07
