Home > Forums > General Forums > Structural Mechanics
Simple supported beam, incorrect solution
Old   November 15, 2017, 11:36
Red face Simple supported beam, incorrect solution
DamianB
optymista93 is on a distinguished road
Hello!
I'm new to ANSYS and don't quite get along with this software. I'm trying to do a simple analysis of beam shown below.
I specified beam section with MM: Processor -> Sections -> Beam -> Common Sections and applied R=0.02257(which corresponds to A=0.0016), N=12, T=8.
I keep getting this incorrect solution where beam is bending the opposite way than it's supposed to.
Here's my code:
 ENTER  /SHOW,DEVICE-NAME  TO ENABLE GRAPHIC DISPLAY
 ENTER  FINISH             TO LEAVE PREP7
 PRINTOUT KEY SET TO /GOPR (USE /NOPR TO SUPPRESS)
 ELEMENT TYPE       1 IS BEAM188      3-D 2-NODE BEAM
  KEYOPT( 1- 6)=        0      0      0        0      0      0
  KEYOPT( 7-12)=        0      0      0        0      0      0
  KEYOPT(13-18)=        0      0      0        0      0      0
 CURRENT NODAL DOF SET IS  UX    UY    UZ    ROTX  ROTY  ROTZ
  THREE-DIMENSIONAL MODEL
 *** PROPERTY TEMPERATURE TABLE    NUM. TEMPS=  1 ***
 SLOC=   1     0.000000
 PRINTOUT RESUMED BY /GOP
 PROPERTY TABLE EX    MAT=      1  NUM. POINTS=  1
 SLOC=   1    0.2100000E+12
 PROPERTY TABLE PRXY  MAT=      1  NUM. POINTS=  1
 SLOC=   1    0.3000000
 ALL CURRENT ANSYS DATA WRITTEN TO FILE NAME= Assignment5_try4.db
  FOR POSSIBLE RESUME FROM THIS POINT
 PRODUCE NODAL PLOT IN DSYS=  0
   INPUT SECTION ID NUMBER                1
   INPUT SECTION TYPE                 BEAM
   INPUT BEAM SECTION SUBTYPE         Circular Solid
   INPUT BEAM SECTION NAME
   BEAM SECTION WITH SECTION ID NUMBER      1 IS OFFSET TO CENTROID
   SECTION ID NUMBER IS:         1
   BEAM SECTION TYPE IS:     Circular Solid
   BEAM SECTION NAME IS:
   COMPUTED BEAM SECTION DATA SUMMARY:
    Area                 = 0.16001E-02
    Iyy                  = 0.20372E-06
    Iyz                  = 0.97194E-23
    Izz                  = 0.20372E-06
    Warping Constant     = 0.37199E-42
    Torsion Constant     = 0.40744E-06
    Centroid Y           = 0.41357E-18
    Centroid Z           =-0.15964E-17
    Shear Center Y       = 0.85597E-18
    Shear Center Z       = 0.33295E-18
    Shear Correction-yy  = 0.85698
    Shear Correction-yz  = 0.81254E-14
    Shear Correction-zz  = 0.85698
    Beam Section is offset to CENTROID of cross section
 KEYPOINT      1   X,Y,Z=   0.00000       0.00000       0.00000      IN CSYS=  0
 PLOT KEY POINTS FROM       1 TO       1 BY      1
 KEYPOINT      2   X,Y,Z=   10.0000       0.00000       0.00000      IN CSYS=  0
 PLOT KEY POINTS FROM       1 TO       2 BY      1
 KEYPOINT      3   X,Y,Z=   20.0000       0.00000       0.00000      IN CSYS=  0
 PLOT KEY POINTS FROM       1 TO       3 BY      1
 LINE CONNECTS KEYPOINTS      1     2
  LINE NO.=     1  KP1=      1  TAN1=   -1.0000   0.0000   0.0000
                   KP2=      2  TAN2=    1.0000   0.0000   0.0000
 LINE CONNECTS KEYPOINTS      2     3
  LINE NO.=     2  KP1=      2  TAN1=   -1.0000   0.0000   0.0000
                   KP2=      3  TAN2=    1.0000   0.0000   0.0000
 SET DIVISIONS ON ALL PICKED LINES
      TO  NDIV =   10,  SPACING RATIO =   1.000
 NDIV AND SPACE CAN BE OVERRIDDEN FOR CURVATURE OR PROXIMITY
 GENERATE NODES AND ELEMENTS   ON  ALL  PICKED   LINES
 NUMBER OF LINES MESHED     =         2
 MAXIMUM NODE NUMBER        =        21
 MAXIMUM ELEMENT NUMBER     =        20
 PRODUCE ELEMENT PLOT IN DSYS =   0
 ***** ROUTINE COMPLETED *****  CP =        42.859
 *****  ANSYS SOLUTION ROUTINE  *****
 PERFORM A STATIC ANALYSIS
  THIS WILL BE A NEW ANALYSIS
 KP   NUMBERING KEY =  0
 LINE NUMBERING KEY =  0
 AREA NUMBERING KEY =  0
 VOLU NUMBERING KEY =  0
 NODE NUMBERING KEY =  1
 TABN NUMBERING KEY =  0
 SVAL NUMBERING KEY =  0
 DOMA NUMBERING KEY =  0
 NUMBER KEY SET TO  0  -1=NONE  0=BOTH  1=COLOR  2=NUMBER
 ELEM NUMBERING KEY =  0
 KP   NUMBERING KEY =  1
 ELEM NUMBERING KEY =  1
 DISTANCE MULTIPLIER FOR WINDOW 1  0.7290
 DISTANCE FOR WINDOW 1   6.016
 DISTANCE MULTIPLIER FOR WINDOW 1   1.372
 DISTANCE FOR WINDOW 1   8.252
 SPECIFIED CONSTRAINT UX   FOR PICKED NODES
 REAL=  0.00000000       IMAG=  0.00000000
 ADDITIONAL DOFS=  UY
 ALL BOUNDARY CONDITION DISPLAY KEYS SET TO  1
 ADDITIONAL DOFS=  UY    UZ    ROTX  ROTY  ROTZ
 SPECIFIED SURFACE LOAD PRES FOR ALL PICKED BEAM ELEMENTS   LKEY = 2
     VALI,VALJ     =    -4000.0        -4000.0
 PRES LOAD SURFACE DISPLAY KEY =  1
 POINT LOAD ON ALL PICKED KEYPOINTS   LOAD LABEL = FY
      VALUES =     -15000.         0.0000
Here's my nodal solution:
 PRINT U    NODAL SOLUTION PER NODE
  ***** POST1 NODAL DEGREE OF FREEDOM LISTING *****
  LOAD STEP=     0  SUBSTEP=     1
   TIME=    1.0000      LOAD CASE=   0
  THE FOLLOWING DEGREE OF FREEDOM RESULTS ARE IN THE GLOBAL COORDINATE SYSTEM
    NODE       UX           UY           UZ           USUM
       1   0.0000       29.352       0.0000       29.352
       2   0.0000       0.0000       0.0000       0.0000
       3   0.0000       28.247       0.0000       28.247
       4   0.0000       26.860       0.0000       26.860
       5   0.0000       24.980       0.0000       24.980
       6   0.0000       22.492       0.0000       22.492
       7   0.0000       19.370       0.0000       19.370
       8   0.0000       15.686       0.0000       15.686
       9   0.0000       11.603       0.0000       11.603
      10   0.0000       7.3786       0.0000       7.3786
      11   0.0000       3.3628       0.0000       3.3628
      12   0.0000       0.0000       0.0000       0.0000
      13   0.0000      -2.3608       0.0000       2.3608
      14   0.0000      -3.7286       0.0000       3.7286
      15   0.0000      -4.2790       0.0000       4.2790
      16   0.0000      -4.1876       0.0000       4.1876
      17   0.0000      -3.6302       0.0000       3.6302
      18   0.0000      -2.7823       0.0000       2.7823
      19   0.0000      -1.8197       0.0000       1.8197
      20   0.0000     -0.91800       0.0000      0.91800
      21   0.0000     -0.25288       0.0000      0.25288
 MAXIMUM ABSOLUTE VALUES
 NODE          0            1            0            1
 VALUE    0.0000       29.352       0.0000       29.352
Can someone please tell me what I'm doing wrong?
Thank You in advance!
optymista93 is offline   Reply With Quote
CFL Condition Matt Umbel Main CFD Forum 19 June 30, 2020 09:20
Pressure distribution on a wall darazsbence CFX 17 October 6, 2015 11:38
grid dependancy gueynard a. Main CFD Forum 19 June 27, 2014 22:22
Future CFD Research Jas Main CFD Forum 10 March 30, 2013 13:26
Wall functions Abhijit Tilak Main CFD Forum 6 February 5, 1999 02:16
