Home > Forums > General Forums > Structural Mechanics
Human Hand Impact Simulation
Old   October 9, 2017, 04:47
Default Human Hand Impact Simulation
Raheel Ahmad
raheel636 is on a distinguished road
I have designed a realistic human hand, With the material model of the bones defined i need to apply forces on different angles to find the maximum force that the bone can bear without failure. Can u guide me towards any work done in this field, the model is made in creo parametric 3.
For the Fingers, i have used a simple pin joint
The pin joint is defined in ansys as a revolute joint with the stop and locks range of 55 and -55 degree
Force applied perpendicular to the fingers of 1 MPa
I want to find when the material w[ATTACH][ATTACH]deformed meshh.png[/ATTACH][/ATTACH]ill become to yield.
raheel636 is offline   Reply With Quote
Old   October 9, 2017, 10:26
rajan19us is on a distinguished road
Dear Raheel,
One of the options is to use Distortion Energy theory. If the Von Mises stress induced exceeds the yield strength of the material, it can be considered as failed/start of the yielding.
Regards,
Rajan
rajan19us is offline   Reply With Quote
Old   October 10, 2017, 15:14
Raheel Ahmad
I am experiencing problems with what seems to be a simple assembly and finger are just simple pin joints with rotation in one axis of revolution i just want to apply a force and see if the bone at the knuckle joint will bear the force or not
human hand, simulation crash
Surface Source - Fixed Temperature? robtheslob FloEFD, FloWorks & FloTHERM 18 May 12, 2017 03:28
Simulation FPEs - turbulence for transient and steady-state? DaveR OpenFOAM Running, Solving & CFD 5 March 5, 2017 16:06
Huge file sizes when Running VOF simulation aarratia FLUENT 0 May 8, 2014 13:27
Supersonic Nozzle Exhaust Simulation mikeh FLUENT 0 May 1, 2014 22:28
Simulation of a complex wing in solidworks flow simulation niels1900 FloEFD, FloWorks & FloTHERM 6 April 20, 2011 11:44
