Restart (continue) converged solution from endpoint |
August 23, 2017, 12:23 |
Rep Power: 10 |
Hey!
So this is basically my problem: I'm modelling steel cables. I fixate one end and impose an axial displacement in one of them. The settings are defined in order to get to a 8% of deformation in 10 secs. My problem is that I want to get one of the models to go beyond this 8%, so I wanted to add a new setp to go from the time t=10 to t=11. It seems that I had the Retain Files After Full Solution option in "No" so after the model converged in the 10 sec I have no restart points available. Is there a way to create a restart point at the time t=10 so I can go from there and add a new setp? Cheers. |
August 31, 2017, 17:25 |
Gwenael H.
Rep Power: 20 |
Well if you didn't save the restart pts in mechanical (rescont option). You can still do singleframe restart procedure (ref to Ansys Mechanical APDL feature - chapter 3). This is only possible if you have the .db, .emat (if created) and .esav otherwise you’ll need to restart from scratch. If you have those files you can add a snippet under the solution branch, resume the db file, enter the solver “branch” with /solve then specify that it’s a restart -> Antype,,Rest Have fun |
2way FSi, Initialize with steady solution, Fluent, Transient Sturcural, System Coupli | mmkkeshavarzi | FLUENT | 1 | June 28, 2024 08:03 |
Strange results in converged solution | Pastukhov | CFX | 5 | January 16, 2017 01:52 |
Total Heat imbalance even if solution 'converged' | AmitKunte | FLUENT | 1 | March 30, 2016 17:39 |
Continue the solution from where the license is timed out | ashtonJ | CFX | 3 | March 12, 2012 20:13 |
solution converged | shaswat | CFX | 7 | February 6, 2012 19:48 |
