Home > Forums > General Forums > Structural Mechanics
glued joint
Old   May 9, 2017, 09:15
Default glued joint
Tim Greulich
probx is on a distinguished road
Hello folks,
first of all I'am using Ansys Workbench 17.1 for quite some time but aside from a few short command snippets I'am not so good in APDL.
Thanks for your help and consideration.
One corner of a rectangular glass pane has to be vertical displaced out of plane, so the glass pane gets a curvature.
But I donīt want to set the displacement directly on the corner of the glass pane, but on a substructure, which is circumferential glued with the pane.
Accordingly the glass pane follows the displacement. (see sketch)
the substructure should consist of rigid bars/beams connected with hinge joints.
Question:
For the glass pane I use a shell element. Which possibilities are there for modelling rigid bars/beams?
Most important is the glued joint. How and out of which elements can I model it to get tensile and shear stress?
(If it is important: the glued joint is quiet elastic, 5mm thick and 10mm wide)
Or has someone an entirely better approach for this problem?
Thanks a lot
probx is offline   Reply With Quote
glue, glued joint, rigid body, shear stress
Problem in bipolar hip joint simulation rifz01 Structural Mechanics 0 February 15, 2017 20:08
Revolute joint in 2D? khhan0543 ANSYS 0 February 2, 2017 15:58
Pointwise-SU2 joint webinar (April 29th) and SU2 v3.1.0 new release fpalacios SU2 News & Announcements 1 April 30, 2014 03:40
About joint face in implicit method quaintchewster Main CFD Forum 0 November 11, 2010 08:04
[ICEM] connected mesh in blocks joint gajemon ANSYS Meshing & Geometry 6 December 17, 2009 17:31
