Home > Forums > General Forums > Structural Mechanics
Spring problem
Old   February 14, 2017, 16:40
Default Spring problem
Radek Vobejda
vobera is on a distinguished road
Hi all,
I would like to ask you for advice about a parametric model.I need help with generate mesh because when i tried to generate it so it was so rough. I didn't try to set contact because the first I need to have a good mesh. I have a problem with stress around the place of load.
! POCATECNI PODMINKY
finish
/clear
RADIUS=5 !Polomer pruziny [mm]
ELEV=3 !Stoupani pruziny [mm]
D=1.2 !Prumer dratu [mm]
DIV=150 !Deleni pri sweepu
YOUNG=210000 !Modul pruznosti v tahu [MPa]
G=81500 !Modul pruznosti ve smyku [MPa]
PI=3.141592653589793
n=5 !Pocet cinnych zavitu [-]
POSUV=500 !Stlaceni pruziny [mm]
!FORCE=100 !Zatizeni pruziny [N]
P=ELEV/(2*PI) !Stoupani na 1 rad
P2=D/(2*PI)
FI=atan(ELEV/(2*PI*RADIUS)) !Uhel stoupani pruziny [rad]
PSI=atan(D/(2*PI*RADIUS)) !Uhel natoceni prurezu [rad]
/prep7
! PRVEK A MATERIAL
et,1,solid186 !Definuje prvni element
et,2,plane183 !Definuje druhy element
et,3,solid187 !Definuje treti element
mp,ex ,1,YOUNG !Younguv modul
mp,prxy,1,(YOUNG-2*G)/(2*G) !Poisson
! TVORBA TELESA
!TVORBA POCATECNIHO ZAVERNEHO ZAVITU
local,11,cylin,0,0,0,0,0,0,0,0 !Vytvori valcovy souradnicovy system pruziny
csys,11 !Prepnuti do souradnicoveho systemu pruziny
wpcsys,1,11 !Posune pracovni rovinu do souradneho systemu pruziny
*do,i,1,8 !Vytvori body pro pocatecni uzavreny zavit
k,i,RADIUS,(i-1)*45,P2*((i-1)/4)*PI
*enddo
*do,i,1,7 !Pospojuje body do sroubovice
l,i,i+1
*enddo
lcomb,all !Vytvori strednici zaverneho zavitu
local,12,cart,,,,,PSI*(180/PI)+90 !Vytvori system pro prurez dratu
wpcsys,1,12 !Vytvori system pro prurez dratu
cyl4,RADIUS,0,D/2 !Vytvori kruhovy prurez
extopt,attr,0,0,1 !Zpusobi ze prurez se potahne kolmo ke strednici
vdrag,1,,,,,,1 !Potahne prurez po sroubovici
local,13,cart,0,0,(D/4)*cos(PSI) !Vytvori system pro srazeni zavitu
wpcsys,1,13 !Vytvori system pro srazeni zavitu
cyl4,0,0,RADIUS+D, , , ,-D !Vytvori valec
vsbv,1,2, ,DELETE,DELETE !Provede rozdil teles
ldele,1 !Odstrani puvodni strednici
!TVORBA CINNYCH ZAVITU
local,14,cylin,0,0,P2*(7/4)*PI,-45,0,0,0,0 !Vytvori valcovy souradnicovy system pruziny
wpcsys,1,14 !Posune pracovni rovinu do souradneho systemu pruziny
*do,i,1,2 !Vytvori body pro dokonceni zaverneho zavitu
k,i+20*(n+3),RADIUS,(i-1)*45,P2*((i-1)/4)*PI
*enddo
*do,i,1,(n*8) !Vytvori body tvorici cinne zavity
k,20*(n+3)+2+i,RADIUS,(i+1)*45,P*((i)/4)*PI+P2*(1/4)*PI
*enddo
k,20*(n+3)+3+n*8,RADIUS,(n*8+2)*45,P*(2*n)*PI+P2*( 2/4)*PI
*do,i,20*(n+3)+1,20*(n+3)+2+n*8 !Pospojuje body tvorici sroubovici
l,i,i+1
*enddo
lsla,u !Odstrani z vyberu cary lezici na carach
lcomb,all !Vytvori jednu sroubovici
extopt,attr,0,0,1
vdrag,6,,,,,,1 !Vytvori cinne zavity pruziny
ldele,1 !Odstani puvodni strednici
!TVORBA KONCOVEHO ZAVERNEHO ZAVITU
local,15,cylin,0,0,n*ELEV+4*P2*PI,0,180,0,0,0 !Vytvori valcovy souradnicovy system pruziny
csys,15 !Prepnuti do souradnicoveho systemu pruziny
wpcsys,1,15 !Posune pracovni rovinu do souradneho systemu pruziny
k,i+30*(n+3),RADIUS,(i-1)*45,P2*((i-1)/4)*PI
*enddo
*do,i,1+30*(n+3),30*(n+3)+7 !Pospojuje body do sroubovice
l,i,i+1
*enddo
local,16,cart,0,0,n*ELEV+4*P2*PI,180,-PSI*(180/PI)+90,180,0,0
wpcsys,1,16
extopt,attr,0,0,1 !Zpusobi ze prurez se potahne kolmo k sroubovici
vdrag,7,,,,,,1 !Potahne prurez po sroubovici
local,17,cart,0,0,n*ELEV+4*P2*PI-(D/4)*cos(PSI),0,,180,0,0
wpcsys,1,17 !Vytvori SS pro dokonceni zakonceni
cyl4,0,0,RADIUS+(D), , , ,-D !Vytvori valec
vsbv,2,4, ,DELETE,DELETE !Provede rozdil teles
nummrg,kp,1e-5 !Pospojuje keypointy
! ZESITOVANI
vsel,s,,,1 !Vybere cinne zavity
latt,1,,2
extopt,esize,DIV,0 !Nastavi velikost elementu
vsweep,1,6,5 !Provede sweep cinnymi zavity
vsel,inve !Vybere zaverne zavity
vatt,1,,3
mopt,tetexpnd,1 !Definuje podminky pro mesh
desize,3,1,50,8,13 !Nastavi velikosti
vmesh,all !Provede zesitovani zavernych zavitu
! KONTAKT
! OKRAJOVE PODMINKY
da,28,all,0 !Na konec pruziny definuje vetknuti
da,16,uz,-POSUV !Na konec pruziny definuje deformacni podminku
! RESENI
csys,1 !Prepnuti do cylindrickeho SS
wpcsys,1,1 !Prepnuti do cylindrickeho SS
/solu
antype,static !Definice analyzy
allsel,all !Vybere vsechno
solve !Spusti reseni
finish
/post1
plnsol,s,eqv,0,1.0 !Vykresli napeti podle podminky HMH
vobera is offline   Reply With Quote
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 05:43
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 06:59
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 07:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 20:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 15:52
