Home > Forums > General Forums > Structural Mechanics
ANSYS static structural solution problem
Old   December 10, 2016, 11:38
Smile ANSYS static structural solution problem
Konstantin
komlesstix is on a distinguished road
Hi everyone!
I try to calculate a deformation of thermal-induced loading of a big electronic model (1657 bodies) in static structural.
First i tried to calculate it with real material properties, which makes this solution really non-linear, but i faced a problem in the solution stage. It just hangs forever at the solution "preparing mathematical model"(was there for 24 hours). And i can`t even look at solver output, because "The solver output file has exceeded the maximum size and will not be displayed here".
Second i decided to calculate this model with only 1 linear material for all bodies, and i had the same result.
And at this moment i just don`t know what to do...I would be thankfull for any kind of help or advice
P.S. pc: 8gb ram ddr4, i7 6700
komlesstix is offline   Reply With Quote
big model, solution, static structural
FSI Structural convergence problem Blizzard99 CFX 13 December 23, 2014 04:45
[Workbench] Static structural by solution of Fluent(with imported mesh from ICEM) Peyman_m ANSYS Meshing & Geometry 6 July 30, 2014 12:11
[DesignModeler] import/export from solution to another Static Structural; zizou3 ANSYS Meshing & Geometry 1 May 5, 2014 09:08
Static structural analysis using ANSYS Mechanical APDL sds10 ANSYS 1 June 23, 2012 01:25
defining a term for a domain using DEFINE_ADJUST MASOUD Fluent UDF and Scheme Programming 1 September 24, 2010 06:08
