Home > Forums > General Forums > Structural Mechanics
Force in node
Old   October 20, 2016, 04:26
Default Force in node
Nicolás
nico_corujo is on a distinguished road
Hi everyone,
I am having some problems with a rotor/stator model. I want to simulate the magnetic force between these components and I don't find the way.
When the upper points of the rotor are getting closer to the stator I need a force in these nodes which try to push them even closer to the stator. Furthermore, I need a force in the lower points that try to atract them to the stator, because they are getting away. And I need the same behaviour if the rotor goes down.
Some ideas?
nico_corujo is offline   Reply With Quote
ActuatorDiskExplicitForce in OF2.1. Help be_inspired OpenFOAM Programming & Development 10 September 14, 2018 12:12
Running UDF with Supercomputer roi247 FLUENT 4 October 15, 2015 14:41
Cluster ID's not contiguous in compute-nodes domain. ??? Shogan FLUENT 1 May 28, 2014 16:03
The fluent stopped and errors with "Emergency: received SIGHUP signal" yuyuxuan FLUENT 0 December 3, 2013 23:56
Force can not converge colopolo CFX 13 October 4, 2011 23:03
