Home > Forums > General Forums > Structural Mechanics
Selecting Fluid-Solid Interfaces on Ansys Mechanical
Old   October 11, 2016, 05:25
Default Selecting Fluid-Solid Interfaces on Ansys Mechanical
kiodos is on a distinguished road
Hi everybody, just arrived in the CDF Online community and glad to post here.
I am currently using Ansys Mechanical in order to carry on a thermal simulation coupled with CFX in Workbench.
My geometry is quite complicate and I need to select all the faces in between the solid and the fluid , manually impossible.
Do you know any automatic or assisted tool in Ansys Mechanical that could aid me in the faces selection of the interfaces ?
Thank you in advance !
kiodos is offline   Reply With Quote
Old   December 20, 2016, 06:06
Jetteke
Jetteke is on a distinguished road
This is quite some time ago, but did you solve your problem, and if, how?
I don't know your geometry, but maybe you use a named selection in the geometry.
You would still have to manually select it, but it might make it a bit easier.
Jetteke is offline   Reply With Quote
ansys mechanical, fluid solid interfaces, geometry ansys
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 15:32
Unstabil Simulation with chtMultiRegionFoam mbay101 OpenFOAM Running, Solving & CFD 13 December 28, 2013 14:12
heat conducting solid within a fluid medium? sieginc. STAR-CCM+ 1 February 19, 2012 12:48
Modeling Solid and Fluid together in Ansys Workbench Sonja ANSYS 1 September 27, 2011 11:49
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
