Home > Forums > General Forums > Structural Mechanics
Error Ansys nonlinear Analysis
Old   September 29, 2016, 08:12
Default Error Ansys nonlinear Analysis
shahrbanoo
shahrbanoo is on a distinguished road
Hi
Dear Engineers
I am modelling a nonlinear buckling for a cylinder in ansys workbench and I activated large deflection. and I faced this error :
An internal solution magnitude limit was exceeded. Please check your Environment for inappropriate load values or insufficient supports. Also check that your mesh has more than 1 element in at least 2 directions if solid brick elements are present. Please see the Troubleshooting section of the Help System for more information.
does anybody know what is it for?
best regards
shahrbanoo is offline   Reply With Quote
Old   September 29, 2016, 10:43
fresty is on a distinguished road
You may have to post some pictures of your mesh and setup...
fresty is offline   Reply With Quote
Old   September 29, 2016, 14:04
shahrbanoo
This is the modelling procedure :
and this is the mesh:
My setting is:
Large deformation : on
load sub steps: 1000
Old   September 30, 2016, 10:04
As a first comment right away, you would need more mesh elements at cylinder cross section/ diametrically... by sharing setup, I would have expected to have some idea or images of fixtures, loads, etc.
How to implement a sensitivity analysis for certain items Mason liu CFX 10 August 17, 2017 09:46
ANSYS WORKBENCH Transfer result of one analysis to a new analysis as preload ingjuanm90 ANSYS 0 July 26, 2016 15:04
nonlinear analysis using bilinear model pashapatil67 Structural Mechanics 0 February 15, 2016 11:55
Eigenfrequencies static and modal analysis Laura_mecheng ANSYS 1 May 15, 2012 04:40
Nonlinear motion analysis of Floating bodies Dr.K.Thiruvenkatasamy Main CFD Forum 0 April 7, 2006 04:50
