Home > Forums > General Forums > Structural Mechanics
What is Your Workflow for CFD Involving Deformed Geometry?
Old   September 6, 2016, 10:25
Default What is Your Workflow for CFD Involving Deformed Geometry?
david
qwe11rty22 is on a distinguished road
Hey there,
Im performing CFD on a deformed geometry, and Im trying to establish a robust workflow. Currently Im in Workbench, and my workflow is this:
1. Static structural: calculation and export .cbd of deformed geometry
2. FE Modeller: create and export parasolid
3. Solidworks: parasolid to dumb solid, create flow domain
4. Design Modeller: share topology/imprint faces etc
5. Mesher: meshing
6. Fluent: run calculation
Currently steps 2 and 3 are problematic. In FE modeller, creating a clean parasolid can be a challenge, and in Solidworks, often the geometry operations fail.
So. I was wondering what everyone else does. Whats your role, what programs do you use, and what is your workflow? What is the easiest, most robust way you have encountered to perform the above steps?
Basically, Im trying to workout whether people in industry have a good way of doing this with no specific software, or use things like geomagic wrap (for example).
Cheers,
David
qwe11rty22 is offline   Reply With Quote
Old   September 15, 2016, 18:15
topspin247 is on a distinguished road
have you tried using the system coupling tool to couple fluent/CFX and ansys mechanical together?
fluent gives force data to mechanical, mechanical gives displacements in the mesh to fluent. repeats until it reaches convergence.
topspin247 is offline   Reply With Quote
Old   March 24, 2017, 01:39
Onur Özcan
oozcan is on a distinguished road
you could do it by selecting ''coupled'' tools like FLUENT to ANSYS Mechanical. But the question is different from your answer. if ''deformed geometry'' is used in FLUENT again or first time, then you should do something different.I am not sure but you can review some chapters about system coupling or two-way FSI system. One of them seems to appropriate for your question.
Kind Regards,
oozcan is offline   Reply With Quote
ansys, deformed geometry, workflow
[ICEM] O-grid around wing geometry Anorky ANSYS Meshing & Geometry 15 November 27, 2017 14:43
Importing CAD geometry and Editing edges to match Ahmed CFX 15 March 21, 2016 13:39
Simulation of Flow through Complex 3D Geometry EmersonKB CFX 5 July 2, 2009 09:17
vitual _ real deneb FLUENT 3 January 22, 2007 05:31
Virtual/Real geometry. Jack Keays FLUENT 9 June 16, 2000 00:39
