Home > Forums > General Forums > Structural Mechanics
When to use solid65 for concrete in ANSYS Workbench (for which type of loading)
Old   July 30, 2016, 13:03
Smile When to use solid65 for concrete in ANSYS Workbench (for which type of loading)
Ahmed Mirghani
mirghani is on a distinguished road
Hi everyone,,
I am modeling the debonding between concrete and CFRP subjected to tangential loading (Mode II) using ANSYS Workbench, I used (CZM/VCCT) techniques to model the debonding. as you know with workbench you can't choose the element type directly. you have to insert commands for Solid65. or use the default solid186.
I have the following quires
1\ For pure tangential force applied on the plate. is it suitable to use solid65 element for concrete in this case. bearing in mind that in some failure modes in experimental there is a lump concrete attached to the plate after separation (Failure). and in others the concrete is intact (just debonding failure).
2\ I tried different element types, but when I use the SOLID 65 command, my model lose convergence too early. If I remove cracking and crushing capability (Suppress the command), the solution runs fine without any convergence problems. (is this due to cracking feature associated with solid65). how can I get the model to converge.
3\ In meshing,If the mid-side nodes are set to "dropped" for the default solid186 (20 nodes), will I get similar behavior as solid65 (8 nodes) (3 DOF/node for both).
4\ I already defined a CZM material in the engineering data for both (Contact debonding & interface delamination). Do I need to insert a command for the "contact" in the CZM material defined in engineering data.,
I already tried the following to get my model to converge for solid65 in workbench:
1- Refining the mesh.
2- Reducing the normal stiffness of the contact region
3- Use newton Raphson residuals.
4- Playing with steps and sub-steps (applying displacement in small intervals).
Any help or suggestions will be highly appreciated.
Thanks in advance.
mirghani is offline   Reply With Quote
Old   December 27, 2017, 05:52
jackhero is on a distinguished road
Originally Posted by mirghani View Post
Hi everyone,,
Thanks in advance.
Hi, I am also working on the similar simulation. I would like to ask you to share the solid65 commands and the crack and crushing commands which you have used in your Ansys simulation.
jackhero is offline   Reply With Quote
ansys workbench 16.0, convergence issues, czm, solid65
[Other] simulation of closing the gate using moving mesh simin_ds OpenFOAM Meshing & Mesh Conversion 8 April 12, 2019 06:49
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 19:00
Strange high velocity in centrifugal pump simulation huangxianbei OpenFOAM Running, Solving & CFD 26 August 15, 2014 03:27
Pressure instability with rhoSimpleFoam daniel_mills OpenFOAM Running, Solving & CFD 44 February 17, 2011 18:08
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 21:50
