Home > Forums > General Forums > Structural Mechanics
problem with stress singularity at T-shape structure
Old   July 25, 2016, 07:42
Default problem with stress singularity at T-shape structure
Soheil Gazeran
soheil93 is on a distinguished road
hi
I have this attached structure belong to a rotor container with mixed solid and shell mesh.At the top of the structure we have a 20mm thickness plate that hold the rotor weight (27500N) in in vertical case.This plate is connected to the structure by a T-shape welded plate (10mm thickness) as its picture attached.A singularity in stress analysis of this structure occurs at the T-shape connection leg and shows the stress value equal to 220 MPa at bottom (solid to solid mesh)and 426Mpa at top(solid mesh joint to shell mesh) .what can I do to eliminate this problem from my study?
please help
soheil93 is offline   Reply With Quote
Problem with airfoil shape optimization robyTKD SU2 Shape Design 7 March 7, 2022 17:18
[ANSYS Meshing] Error in Workbench "Unable to attach to geometry file" Jeremie84 ANSYS Meshing & Geometry 70 October 25, 2017 17:03
[blockMesh] Wedge shape meshing problem! aydemirk OpenFOAM Meshing & Mesh Conversion 3 August 20, 2014 11:50
Fluid Structure Interaction problem! SamerAli OpenFOAM Running, Solving & CFD 0 June 12, 2013 05:30
singularity problem in cylindrical coordinate dallybird Main CFD Forum 6 June 3, 2003 12:47
