Home > Forums > General Forums > Structural Mechanics
ANSYS Mechanical - change convergence criteria
Old   July 7, 2016, 18:06
Default ANSYS Mechanical - change convergence criteria
Kegan Leckness
KeganLeckness is on a distinguished road
Hi all,
How can you change the convergence criteria in ANSYS Mechanical?
If you monitor force convergence, for example, you can clearly see values like 2e-3 or 1e-8. How can you choose those values. The only options I see are under Tools > Options > Convergence > Target Change, but here, the default value is 20. I need to do a sensitivity analysis and change the convergence criteria from .001 to 1e-6, but cannot seem to do so.
KeganLeckness is offline   Reply With Quote
Old   July 25, 2016, 12:03
Default Problem with 'Command' in Ansys v17
David
mrkmrk is on a distinguished road
I defined a new material properties for my geometry in ansys mechanical v17 using "command" code. The problem is, the simulation terminated in the beginning with no error.
In ansys V15 I could do this with no problem while in V17 I can't.
I would be thankful if anyone can help me with this problem.
mrkmrk is offline   Reply With Quote
Old   May 12, 2022, 06:57
Alexander Kazantcev
AlexKaz is on a distinguished road
EQSL and CNVTOL from apdl.
AlexKaz is offline   Reply With Quote
Fluent in Ansys Workbench : Change Working Directory sral FLUENT 4 March 29, 2019 11:29
Pro/E to ANSYS Parameterization Guide Trues ANSYS 4 April 18, 2018 06:52
Time step size & convergence absolute criteria yuitsang FLUENT 5 April 15, 2013 05:27
convergence criteria danigorgeos Autodesk Simulation CFD 3 January 4, 2013 17:52
convergence criteria iuaniu CFX 3 September 24, 2009 20:20
