Structural Analysis on a (large) Triangular Mesh Based on 3D Laser Scan |
February 5, 2016, 17:15 |
Florian Rist
Hi!
I have a triangular mesh obtained by a 3d Laser scanner and now I'd like to run a few structural analysis , mainly simulate deflections under certain static loads. The mehs is and has to be relatively large, say 100.000 faces. Whats the proper way to deal with this sort of 'geometry' data? From a few hints that I read I think the ICEM CFD component might be used to do the trick, but it does not seam to be strait forward. See you Flo |
3d scan, mesh import, stl |
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface | Kryo | OpenFOAM Meshing & Mesh Conversion | 13 | February 17, 2022 08:34 |
Star CCM Overset Mesh Error (Rotating Turbine) | thezack | Siemens | 7 | October 12, 2016 12:14 |
[ICEM] surface mesh merging problem | everest | ANSYS Meshing & Geometry | 44 | April 14, 2016 07:41 |
[ICEM] Orthogonality/Skew issues in 3D unstructured mesh | eddyy19g | ANSYS Meshing & Geometry | 3 | February 13, 2014 10:36 |
engrid -> save as .stl with boundarie codes | Zymon | enGrid | 31 | August 29, 2011 14:40 |
