November 11, 2015, 21:58 |
Axial Fan Modal Analysis ANSYS
Rep Power: 11 |
We have an axial fan in the lab that apparently vibrates badly ("wobbles") at certain frequencies. To find the resonance and the bad frequencies, I decided to do an ANSYS modal analysis. I am still pretty new to it, and have a few questions. 1) Regardless of how many modes I pick, ANSYS picks certain frequencies. What is the significance of these frequencies? 2) I cant seem to input a rotational velocity into ANSYS. When I add a "Rotational Velocity" Modal, I try to input a 25 rad/s rotation but it does not go through...(I dont get the check mark to its left). So my question is, what is the frequency? Is that equivalent to rotation? 3) So I have just put a fixed point in the center of the fan, and run the analysis. I am getting different colors for the first 3 modes, but the shape seems intact. After mode 4, the entire shape gets ruptured...what does that mean? Lets say all the modes until 150hz had a smooth shape, and the next mode at 300hz is a ruptured shape. Does that mean that the "bad wobbly vibration" happens between 150hz and 300hz? 4) How do i find resonance frequency from these results? Thanks!! |
November 12, 2015, 22:02 |
Rep Power: 11 |
So I just connected a Static Structural module and was able to add a rotational velocity using that...why couldnt I do it within modal?
December 29, 2015, 09:27 |
miguel pace
Rep Power: 10 |
There is an good explanation on Vibration and Noise of an Axial Flow Fan http://www.pp.bme.hu/me/article/viewFile/7948/6760
January 12, 2016, 03:55 |
Escorts service in Chandigarh
Aman
Thank You.Chandigarh escorts
[ANSYS Meshing] modal analysis by ansys using existing mesh | hityangsir | ANSYS Meshing & Geometry | 0 | March 5, 2014 02:08 |
Acoutic fan analysis | arunraj | CFX | 3 | October 4, 2012 19:54 |
[ANSYS Meshing] mesh around axial fan | Cecco | ANSYS Meshing & Geometry | 3 | May 30, 2012 11:18 |
[ANSYS Meshing] steady-state thermal analysis in ansys workbench | zenwalk | ANSYS Meshing & Geometry | 3 | March 19, 2012 22:40 |
reg-Classical method of axial fan design | ramamoorthyramanan | Main CFD Forum | 0 | June 25, 2010 01:45 |
