Home > Forums > General Forums > Structural Mechanics
Mechanical fails, MAPDL doesn't..FSI
Old   August 17, 2015, 17:34
Default Mechanical fails, MAPDL doesn't..FSI
Kegan Leckness
KeganLeckness is on a distinguished road
I'm encountering some problems with Mechanical. When I run analyses in MAPDL and Mechanical with the same mesh, BC's, material properties, and analysis settings (Large Deformation, time step size, etc.) Mechanical fails to complete due to excessive mesh deformation. MAPDL completes the run without reporting such an error. I'm using Fluent during two-way FSI simulations. I would like to couple MAPDL with Fluent (instead of Mechanical), but cannot find any way to do so.
Is there a prodecure by which I can run MAPDL/Fluent analyses within Workbench? Otherwise, is there a way to make Mechanical and MAPDL spit out their settings so I can determine what is going on, and why only one of the programs is running successfully?
Thanks,
Kegan
KeganLeckness is offline   Reply With Quote
2way FSI Fluent Mechanical SETUP Problems MainzerKaiser ANSYS 7 May 20, 2016 12:22
[ICEM] 2 way FSI, CFX + Mechanical + ICEM, Remesh, Deformation due to fluid flow binoyjjohn ANSYS Meshing & Geometry 8 June 25, 2014 10:00
About 2 Way FSI (CFX+ANSYS Mechanical) shreyasr ANSYS 2 November 7, 2012 14:30
[Other] Remeshing fails in FSI pramo4d ANSYS Meshing & Geometry 0 February 17, 2011 06:14
how to extend FSI 2D codes to 3D, need advises abouziar Main CFD Forum 1 May 30, 2008 05:08
