July 29, 2015, 13:17 |
ABAQUS Crushable Foam Model Calibration
I am currently facing difficulties in calibrating abaqus crushable foam model with my experimental results. I think I am bit confused about what values needs to be input in the model. Right now my elastic properties are: E=400 MPa, v=0 (because its crushing) In plastic under crushable foam I use compression yield stress ratio =1 and hydrostatic yield stress ratio =0.1. Under crushable foam hardening card (Here I am confused), I convert the engineering stress to true stress using (T.stress=E.Stress(1+E.strain)) and I convert the engineering strain to first true strain using (T.strain=ln(1+E.strain)) and then to plastic strain using P.Strain = T.strain - Yield Stress/E So in short, I input True Stress and Plastic strain in the Hardening table. 1) Is this procedure right or am I approaching wrongly? 2) What do I need to extract from Abaqus in terms of Stress and Strains to compare with my experimental data ? (do I need to plot PE22 and S22?) Please guide me in this regards. |
[snappyHexMesh] How to define to right point for locationInMesh | Mirage12 | OpenFOAM Meshing & Mesh Conversion | 7 | March 13, 2016 15:07 |
Prism Layers issue for Model replicating Abaqus Co-Sim Mechanical Coupling Tutorial | MTabone | STAR-CCM+ | 4 | April 14, 2015 03:28 |
[blockMesh] non-orthogonal faces and incorrect orientation? | nennbs | OpenFOAM Meshing & Mesh Conversion | 7 | April 17, 2013 06:42 |
channelFoam for a 3D pipe | AlmostSurelyRob | OpenFOAM | 3 | June 24, 2011 14:06 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 15:11 |
