Home > Forums > General Forums > Structural Mechanics
SPECTRUM ANALYSIS-Subscript range error
Old   February 23, 2015, 01:15
Default SPECTRUM ANALYSIS-Subscript range error
muthu kumar
eramuthukumar is on a distinguished road
Dear all,
While doing Spectrum analysis i got the following SUBSCRIPT range error .
I get the following error message when running Spectrum analysis.
"Subscript range error. Parameter_ZC is dimensioned as 3, but location 4 is being requested"
"No data exists for dimensioned parameter_ZC with subscript 4"
"The above error occurred processing field = _ZC(_Z1) Line = *SET,_z3,(_z3+1)."
I did a modal analysis before the spectrum analysis. I dont really understand how should SED be use in ANSYS 14.0. THis option is not available in older version.
PF can be calculated, but when I click on "Calc Control", the error message appear.
Please help.
eramuthukumar is offline   Reply With Quote
error in ansys, spectrum, subscript
Compile calcMassFlowC aurore OpenFOAM Programming & Development 13 March 23, 2018 08:43
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) Yogini Fluent UDF and Scheme Programming 7 October 3, 2012 08:24
CGNS lib and Fortran compiler manaliac Main CFD Forum 2 November 29, 2010 07:25
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 21:50
Compiling problems with hello worldC fw407 OpenFOAM Installation 21 January 6, 2008 18:38
