Home > Forums > General Forums > Structural Mechanics
ANSYS Workbench Mesh-Nodes ID
Old   January 17, 2015, 09:16
Smile ANSYS Workbench Mesh-Nodes ID
Guoqing Liu
Qingguo is on a distinguished road
I have encounted a problem when I analysis the thermal stress of the structure.
*** WARNING *** CP = 1859.750 TIME= 15:55:37
Contact element 678402 (real ID 142) status changes abruptly from
contact (with target element 678578) -> no-contact.
But I can not find the the location of the element 678402(real ID 142).
How can i know the node ID?
Thanks very much!
Qingguo is offline   Reply With Quote
Old   April 10, 2015, 02:16
Florin's Avatar
Florin Gheorghe
Florin is on a distinguished road
Hello Qingguo,
This how you can see the node in problem.
Go to Mechanical and create a Named Selection.
In the details of the Named Selection, for Scoping Method choose Worksheet; a table will open in Graphic interface.
Right click here and select Add Row and set the following:
Entity = Mesh Node
Criterion = Node ID
Value = 142 (ID of the problem node)
Hit Generate, which is above the table; go to the Graphics tab and visualize the problem node; the node is shown in pink and the geometry is given along to locate it easily.
Hope this helped.
Best regards,
Florin
Florin is offline   Reply With Quote
mesh, workbench 14.5
How can I save a mesh file in ANSYS Workbench V12 for standalone mode CFX-Pre? fkonias ANSYS Meshing & Geometry 22 March 18, 2017 10:38
Ansys workbench comprising many mesh containters to OF Mesh Aj Nair OpenFOAM Pre-Processing 0 November 30, 2014 03:11
[ANSYS Meshing] Multi-size mesh generation in ANSYS 12.1 Workbench nsakib520 ANSYS Meshing & Geometry 0 April 6, 2012 13:37
Mesh Seeds in ANSYS WorkBench Meshing smcp ANSYS 1 March 12, 2012 14:16
2D mesh by ANSYS Workbench 8.1 Dome CFX 4 June 6, 2005 07:20
