Home > Forums > General Forums > Structural Mechanics
Ansys Structural Environmental Temperature
Old   October 31, 2014, 15:32
Default Ansys Structural Environmental Temperature
steve
zytra is on a distinguished road
Hi
I am doing some FSI integration (fluent to static structural) in ansys and I am facing a question.
What I am doing in fluent is a simulation of a liquid cooled solid that is being heat up by natural convection. Nothing very complex here.
Then I am exporting the CFD results into Static Structural.
In the problem condition there is a Environmental Temperature that I apparently have to fill out. Default is 22C. Obviously since the thermal problem has been solved by fluent, and I am only interested in the stress and deformation in the solid (resulting from the solved thermal problem) this "environmental temperature" is not desired here.
I haven't been able to disable this settings so that the problem is solved solely on the temperature map in my solid.
I have "worked" around by exporting the average temperature as a parameter in fluent, and then making the "environmental temperature" an input parameter. And linking both in workbench, that way the environmental temperature is much closer to the actual solid temperature map, however, since I am looking at extremely small deformation (of the order of E-8), even small difference on the temperature have a huge impact on the results.
is there a way to disable this environmental temperature setting in static structural?
thanks
Steve
zytra is offline   Reply With Quote
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 07:27
Ansys Transient Structural thda7 Structural Mechanics 1 August 23, 2014 05:15
Ansys structural and fluent for FSI assafwei FLUENT 1 June 20, 2014 11:56
Solution not convergin in ansys workbench static structural amit2590 Structural Mechanics 1 May 16, 2014 18:19
From Fluent 6.23 to ansys 12 structural Rich1979 FLUENT 0 April 18, 2011 10:40
