Home > Forums > General Forums > Structural Mechanics
Solution not convergin in ansys workbench static structural
Old   May 9, 2014, 07:20
Default Solution not convergin in ansys workbench static structural
amit kumar baghel
amit2590 is on a distinguished road
Hi
I am working human artery where objective is to study fluid interaction.It consist two part in first part i did CFD study in second part i am doing structural analysis.diameter of artery is 2.17 mm,thickness of wall is 0.9 mm,length of artery is 20 mm.I run CFD simulation using non Newtonian power law.Boundary condition for cfd at inlet is velocity inlet and its value is 1.116 m/s and outlet is pressure outlet.I completed cfd study now for fluid intraction study i imported my pressure data into ansys static structural analysis.Main problem ariese here.
Property of material in static strcutural analsysi i am using- initial shear modules -3000 pa,incomprehensibility parameter - 6.67e-06
I kept fixed condition at inlet in outlet in structural analysis..I imported pressure from ansys fluent.Now when i run the simulation artery get deformed and I am getting this error every time "The solver engine was unable to converge on a solution for the nonlinear problem as constrained. Please see the Troubleshooting section of the Help System for more information."
i increased sub step but same thing is happening. Please help me figure out this.I am facing this problem form long time.
amit2590 is offline   Reply With Quote
Old   May 16, 2014, 18:19
Default Stresses in cylinder
Firas
Firas is on a distinguished road
I modeled 3d cylinder with 3mm thickness by static structure ....my problem emerged when I imported my model to workbench , there was no problem with messaging it but I suffered from putting 2.5 mpa pressure on the internal surface for studying stress ...there is no internal surface on the surfaces when I want to define internal pressure ...may I get any answer for this case plz
Firas is offline   Reply With Quote
ANSYS Workbench on "Uncertified" Linux Distros hsr CFX 289 April 20, 2023 10:23
FLUENT installation on UBUNTU 12.04 (LTS) teymourj FLUENT 2 March 1, 2017 23:24
Ansys Static Structural Zero Structural Mechanics 0 January 15, 2014 20:39
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 03:58
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 19:07
