Home > Forums > General Forums > Structural Mechanics
Ansys Structural- Symmetry BC Problem
Old   April 8, 2014, 15:34
Question Ansys Structural- Symmetry BC Problem
Mudassir
Mudassir is on a distinguished road
I am doing a structural analysis on a very basic geometry, Its a Cylinder(Crucible or Glass like geometry), i am Doing this analysis on Half of the geometry and trying to apply the symmetry conditions to accomodate for the rest of the geometry. The problem is , When i fix(FIXED Support) the Bottom Face (Base of the crucible) i get symmetric results, But when the bottom is "Frictionless Support" the results show that it is not behaving like a Cylinder, it means that the symmetry is not working fine? Can anyone please help in this matter?
Image-1: Symmetry Face.
Image-2,3[File: "7-deform","7-stress"] : Results with Bottom Fixed (Show Symmetric Behaviour)
Image-4,5[file name "Deform","Stress"] : Results with Bottom as Frictionless Support(Doesnt seem to be symmetric)
Thanks!
Mudassir is offline   Reply With Quote
Old   April 17, 2014, 03:07
Florin's Avatar
Florin Gheorghe
Florin is on a distinguished road
Hello Mudassir,
I understand that you get different results using different boundary constraints.
I think the problem is not the symmetry BC, but the way you applied the constraints on the bottom.
Can you elaborate on the way you applied the loads?
Best regards,
Florin
Florin is offline   Reply With Quote
Old   April 17, 2014, 10:13
Mudassir
Thanks Florin,
I just got this problem solved, but i am having some other problem now, May be you can help in that too.
I am doing stress analysis as yo can see above, I need GUIDANCE regarding Meshing of this.
What type of mesh should i use? How to assure the mesh quality, and that results are near to what would be actually, Etc Etc.
Can you help?
Thanks again!
Mudassir
Old   April 23, 2014, 06:35
Florin's Avatar
Florin Gheorghe
Hello Mudassir,
I would use hexa elements; make sure the midside nodes are on; you can switch the on in global mesh settings, advanced.
Make sure you have at least 3 elements on the thickness; to do this you can impose a proper the size of elements on the body.
After the analysis is done, I recommend to do a convergence study, to be sure that you results have converged.
Best regards,
Florin
ansys, mechanical, structural, symmetry bc
FSI Structural convergence problem Blizzard99 CFX 13 December 23, 2014 04:45
Problem of Ansys for machanical a element or a group of elements lovelyeverything ANSYS 0 April 18, 2012 23:54
[ANSYS Meshing] 2-Way FSI meshing problem using ANSYS 13 workbench john881129 ANSYS Meshing & Geometry 0 January 9, 2012 02:19
Ansys 12 Workbench problem when generating volume mesh Sveink ANSYS 5 January 6, 2010 04:17
problem in import ANSYS mesh sheryl CFX 2 April 30, 2005 22:30
