Home > Forums > General Forums > Structural Mechanics
static structural analysis
Old   April 2, 2014, 04:10
Default static structural analysis
Khushali
Khushali is on a distinguished road
I want to perform static analysis of industrial automated storage for 1 ton pallet load. I don't much about structural analysis in ansys. if someone know how to proceed please tell me as soon as possible. I am attaching the image of model what I made in Pro-E.
Khushali is offline   Reply With Quote
Old   April 7, 2014, 16:36
siw
Stuart
siw will become famous soon enough
I assume that the components of your model are all 3D solid bodies judging from your picture. I don't use Pro-E so what I say could be done there. However, I'm given SolidWorks 3D CAD models from the designers and I prepare it for FEA in ANSYS DesignModeler. So in this instance I'd make as many components as possible into 2D surface bodies (Mid-Surfaces) and use Surface Extensions to join up the mid-surface gaps. If you leave them as 3D solid bodies and mesh them as 1 element thick ANSYS will give you a warning message, the solution will take longer to run and be less accurate (all to do with element integration points). Then put as many components as possible into Multi-Body parts in DesignModeler. Which when in ANSYS Mechanical (or Structural or Professional depending upon your license) will reduce the amount of bonded contacts. Again I assume all your contacts are bonded and not non-linear contacts. Also that will make the mesh nodes conformal. Then just set up the supports and loads as required and solve. If the stresses in localized areas need resolving more accurately you can then use the new to version 15.0 shell-solid sub-modelling feature - see the tutorials on the ANSYS Customer Portal for the details. Also there's lots of presentations on the Customer Portal about things like making 2D Surface Bodies, Multi-Body parts, post-processing for 2D surface bodies etc - as an ANSYS customer you can (and should) download and read them all.
siw is offline   Reply With Quote
Old   April 8, 2014, 10:06
Khushali
thanks for the reply.... I will read the presentations...
Old   June 4, 2014, 13:23
NeNaD
skinnyfluid is on a distinguished road
Dear siw,
I hope that you can help me to overcome my problem. In ANSYS Mechanical, I want to change default SOLID185 element to SOLSH190. My model is an solid fin or wing. I want to treat model as the shell or plate, not as the full solid model. I tried with APDL command insertion but unsuccessfully. What to do?
Thank you in advance.
All the best,
SF
skinnyfluid is offline   Reply With Quote
Old   June 4, 2014, 14:39
siw
Stuart
I do not have access to ANSYS Mechanical right now so you'll have to try a quick demo for yourself to check this. I guess you can also do this with APDL, but I do not use that so cannot help there.
However, in ANSYS Meshing assign a Sweep mesh method to the thin solid body of interest. Then set Src/Trg Selection to either Automatic Thin or Manual Thin. You will then have Element Option available and if you set that to Solid I think that invokes the solid shell elements. Again, make a simple model and check for yourself by looking through the Solution Information > Solver Output script as that lists the element types used.
Old   June 5, 2014, 11:39
NeNaD
I tried with Sweep too. I know for Automatic and Manual Thin option. It doesn't work with different Src and Trg area.
Thank you anyway
Old   December 4, 2014, 06:30
Default How to Extrude the 2D area to 3D area
Siva Krishna
tatasiva is on a distinguished road
Kindly tell me the process of extrude for 3D shapes
tatasiva is offline   Reply With Quote
error: uninitialized local variable 't' used MASOUD Fluent UDF and Scheme Programming 5 October 17, 2016 05:24
Static structural Analysis using temperature profile from CFX transient solution bhavik139 Structural Mechanics 3 July 7, 2013 21:51
Static structural analysis of two overlapping tubes kept together by pins-ANSYS Mech. Giulio89 Structural Mechanics 5 May 17, 2013 15:14
Static structural analysis using ANSYS Mechanical APDL sds10 ANSYS 1 June 23, 2012 01:25
Import transient cfx-results for static structural analysis in Ansys WB 13 Colt Seavers ANSYS 1 August 11, 2011 07:01
