December 23, 2013, 06:43 |
Sphere Deformation Simulation
Milad
Rep Power: 13 |
I am trying to simulate the deformation of a sphere which is placed between 2 cylindrical plates and is in contact with them. The plate in the bottom is fixed by FIXED SUPPORT and the plate on the top is under a SURFACE FORCE. I want to simulate the deformation of the sphere. I have couple of questions: 1. How can I give different mechanical data such as young's modules for each of the 3 bodies SEPARATELY? because I don't want the whole geometry to have the same mechanical properties. 2. Since everything is symmetric in my simulation, I expect to have symmetric results, but as you can see in results I get some deformation in the top plate which is not symmetric, I wonder why it is like that???? Thanks for any help |
December 23, 2013, 08:10 |
Alex
Rep Power: 49 |
Your physical model may be symmetric, but your computational model is not.
With the Boundary conditions you described so far, your model is under-constrained and Ansys will add weak springs to prevent the solution from diverging. You have to add boundary conditions to your model to make fully-constrained. A simple solution would be to actually make use of the symmetry and model only a segment of the full model. With symmetry boundary conditions at the new boundaries you can already constrain some degrees of freedom which should be enough to make the model fully constrained. |
December 23, 2013, 08:19 |
Milad
Rep Power: 13 |
Thanks for your answer, I just wanted to fix the displacement of the plate to prevent it from deformation, but it didn't work.
December 24, 2013, 09:16 |
#4 | |
Milad
Rep Power: 13 |
February 28, 2014, 04:52 |
Florin Gheorghe
Rep Power: 13 |
Hello amingh,
You just have to create the materials in Engineering Data (you must know the properties) and when in Mechanical, you can assign them to the desired geometry.
Best regards, Florin |
ansys, deformation, fea, mechanical, sphere |
simulation of free falling sphere into calm water? | pedyspider | CFX | 17 | June 25, 2015 12:03 |
a simulation with rotation and vibration | liuzexiang | CFX | 34 | September 16, 2013 09:12 |
Convergence of jet flow simulation | MiraLisa | FLUENT | 0 | August 15, 2013 05:44 |
Requiring some help regarding tornado simulation | amarjogot | Main CFD Forum | 0 | June 20, 2013 13:26 |
Spinning sphere simulation | Herry | CFX | 1 | May 24, 2003 10:33 |
