Ansys Mechanical 14.0, Axi-symmetric condition in Ansys Mechanical? |
October 27, 2013, 10:26 |
SteveFinnan
Rep Power: 13 |
How to apply pressure on the inner surface of the wall of cylinder, in such a way that every point on the inner surface will have the uniform pressure?
As you can see from the diagram, I have two different geometry, the stent and balloon. The balloon is the cylindrical shape object, which is inserted into the stent. I want to create a simulation, in which I apply the load on the inner surface of the balloon, then the balloon will expand, which in turn expand the stent. Ansys Pressure Load.jpg main5x.png Please help me. Thanks |
April 8, 2014, 16:33 |
Mudassir
Rep Power: 12 |
Just apply Pressure on the inner wall and select it to be Normal to surface.
STEPS: 1-Select 'Static Structural" in outline 2- Apply Loads> Pressure 3- Select inner wall and Apply pressure this to it. 4-In Details of Pressure select "Define By = Normal To" You are done! |
Can't restart 2-way FSI using ANSYS 14.0 Workbench | MSHowes | ANSYS | 2 | July 3, 2014 14:30 |
Delta Functions within Ansys Mechanical | Stephen Waite | Structural Mechanics | 2 | July 29, 2013 09:56 |
Results are different for Ansys Fluent 14.0 and Fluent 6.3 | syavash | Fluent UDF and Scheme Programming | 1 | February 17, 2013 02:09 |
Axi - symmetric flow in OpenFOAM | ivanddd | OpenFOAM Running, Solving & CFD | 0 | April 2, 2012 06:06 |
doubts about axi symmetric moving reference frame and | eers | Main CFD Forum | 0 | July 9, 2009 16:53 |
