February 16, 2012, 12:15 |
posdat file to record heat release
Robert
Rep Power: 15 |
Hello
I'm running a transient reacting simulation. I want to be able to plot contours of heat release rate throughout my domain. I know that I need to write a subroutine in posdat.f in order to calculate and store values of heat release rate from each of my cells. Has anyone managed to do this successfully, and if yes, would you mind sharing your posdat.f file with me? Cheers Rob |
February 20, 2012, 22:38 |
zheng jianjun
Rep Power: 16 |
c************************************************* ************************ subroutine posdat(level) c Post-process data C************************************************* ************************ C--------------------------------------------------------------------------* C STAR-CD VERSION 4.06.000 C--------------------------------------------------------------------------* USE allmod IMPLICIT NONE INCLUDE 'std.inc' c c Argument variables INTEGER level C------------------------------------------------------------------------- C C This subroutine enables the user to output data and is called C at the beginning and at the end of each iteration/time step, C i.e. C if (level.eq.1) then c.> called at the beginning of iteration/time step C else if (level.eq.2) then c.> called at the end of iteration/time step C end if C Any user code which is not enclosed in the IF condition will C be executed for both calls C C Note: 1. File units available to the users for opening their own C files are from 84 to 89. Users may write to unit 6 or 60 C if they want to see their output on the terminal or C the run file. C 2. All variables passed to this routine use STAR cell C numbering, which is different from pro-STAR cell numbers. C pro-STAR cell number can be obtained from a STAR cell C number ICSTAR by ICPROSTAR=ICLMAP(ICSTAR) C------------------------------------------------------------------------- c Local variables INTEGER nd,nset,i,j,k,icprostar INTEGER moni(4) c-定义数组,存储4个prostar单元编号 INTEGER monis(4) c-定义数组,存储对应的star单元编号 DATA moni/111,112,113,114/ c -给定4个prostar单元编号 DATA monis/0,0,0,0/ c&&& if (intflg(128).eq.0) then CC--- Find out cell id of star from cell id of prostar,找出与prostar单元编号对应的star单元编号 call cset(cs,0,ND_ALL,NSD_ALL,INTERNAL) do nset=1, cs%no do i=cs%ns(nset),cs%ne(nset) icprostar=iclmap(i) do j=1,4 if(icprostar.eq.moni(j))then monis(j)=i write(6,*)'monitor',j,'icprostar=',icprostar, & 'icstar=',monis(j) write(60,*)'monitor',j,'icprostar=',icprostar, & 'icstar=',monis(j) exit end if end do end do end do CC--------------------------------------------------- C first iteration, so open files,第一步,打开三个文件,用于存储u,v,p if (.not.parrun) then open(85,file='MonitU',form='formatted',status='unk nown') open(86,file='MonitV',form='formatted',status='unk nown') open(87,file='MonitP',form='formatted',status='unk nown') end if intflg(128)=1 c else files already open end if c if (level.eq.1) return c CC--获取u,v,p,并写入文件。 if (.not.parrun) then write(85,800) iter,(u(1,monis(k)),k=1,4) write(86,800) iter,(u(2,monis(k)),k=1,4) write(87,800) iter,(pabs(monis(k)),k=1,4) end if 800 format(i8,1p,5e11.3) end C |
February 21, 2012, 13:17 |
Robert
Rep Power: 15 |
Thanks Skylent, but I really need it all in western script. StarCD can't understand the Chinese symbols and unfortunately neither can I.
Any chance of a translation? Cheers Rob |
March 1, 2012, 13:24 |
Robert
Rep Power: 15 |
Ah sorry Skylent - I just realised that the non-Western characters only appear in comment lines. So the compiler doesn't need to read them.
I'm a Fortran novice, so please excuse me. I've now got my simulation running with the posdat.f subroutine. I'll see over the next few days whether I've set it up properly. Cheers Rob |
GPU Linear Solvers for OpenFOAM | gocarts | OpenFOAM Announcements from Other Sources | 37 | August 17, 2022 15:22 |
[swak4Foam] swak4Foam-groovyBC build problem | zxj160 | OpenFOAM Community Contributions | 18 | July 30, 2013 14:14 |
Compiling OpenFOAM13 on AMD64 with Redhat Enterprise | mbeaudoin | OpenFOAM Installation | 20 | June 17, 2008 07:43 |
Results saving in CFD | hawk | Main CFD Forum | 16 | July 21, 2005 21:51 |
error while compiling the USER Sub routine | CFD user | CFX | 3 | November 25, 2002 16:16 |
