January 20, 2012, 08:56 |
Creating an O Grid in Proam
Nicholas
Rep Power: 17 |
I'm trying to automate the creation of what should be a fairly simple mesh. A cylindrical O mesh, wrapped around a Cartesian "square mesh". I believe that ICEM cfd and other meshing programmes have commands for creating these types of meshes, but I can't find one for Star. Any ideas? Thanks |
January 20, 2012, 12:45 |
Pauli
Rep Power: 17 |
Their is no single dedicated command. You need to use several commands. Its been a long time but I think it went like this:
1) Use vc3d to create the square. 2) Use vgen with the cgen option to extrude the nodes along one edge "radially outward". 3) use vmod to set/adjust the outer radius of the newly created cells. 4) use vsmooth to smooth the center "field" of the new cells. 5) use cgen with the vgen option to copy the new cells to the other faces. 6) vmerge it all together. Simple once you get the hang of Prostar grid manipulation. Depending if you are creating a cylinder or a sphere. you'll need to perform the operation in a cylindrical or spherical csys. |
January 20, 2012, 13:04 |
Nicholas
Rep Power: 17 |
Thanks for the help Pauli,
I've created the mesh in a similar way to how you have described, but this is (as far as I can tell) a very manual process that cannot be automated for batch meshing (I'm going to be creating a lot of meshes of arbitrary sizes). I seem to fall over when it comes to modifying the position of the new radial cells, the numbering system seems to make it impossible to redistribute. I'm thinking of try to go down the block meshing route. Thanks again for the help. |
January 20, 2012, 14:38 |
Pauli
Rep Power: 17 |
Any command you can enter at the Prostar command line can be used in batch mode. I'm sure this is a batch capable process.
Its a structured mesh, so the numbering is possible. You just need to work out the "pattern". Sometimes its simpler (or required) to leave large holes in your numbering system. Sometimes you want to compress your node numbers, sometimes you don't. It just takes a bit of foresight & planning. The specific technique is very problem dependant. Prostar has commands to query maximum node number, etc. (see the *get command). You can also create variables (see *set & *sset) & use them in your batch script.. |
January 20, 2012, 15:25 |
Joern Beilke
Rep Power: 20 |
One way:
!Creates a single butterfly pipe !Set radius : *set r1 1.5 !Set number of cells in radial direction : !(This number should be even) *set nr1 12 !Set length : *set l 10 !Set no of z planes : *set nz 25 *set nv1 1 *set nv2 nr1 + nv1 *set nr12 nr1 / 2 v nv1 0 v nv2 r1 vfil nv1 nv2 vset,, vgen nv2 nv2 vset,,,0 r1 / nr1 ctab 2 shell 8 c nv1 nv1 + 1 nv1 + 1 + nv2 nv1 + nv2 cgen nr1 1 1 cset,, cgen nr1 / 2 nv2 cset *set nc1 nr1 / 2 - 1 * nr1 + 1 *set nc2 nr1 / 2 + nc1 - 1 cgen nr1 / 2 + 1 nv2 nc1 nc2 *set nvf2 nr1 / 2 * nv2 + nv2 csys 2 v nvf2 r1 45 vfil nv2 nvf2 nr1 / 2 - 1 vfil nr1 / 2 + 1 nv2 nr1 / 2 - 1,,,nr1 / 2 + 1 nv2 *set nvf3 nv2 * nr1 + nr12 + 1 vequ nvf2 nvf3 vfil nvf3 - nr12 nvf3 vfil nr12 * nv2 + 1 nvf3 - nr12 nr12 - 1,,,nr12 + 1 1 vset all vgen 4 nv2 * nv2 vset,,,0 90 cgen 4 nv2 * nv2 all cset all vset news cset vmer vset,,.001 cont vset news edge !vsmoo 1 50 vell 50 cset,, vset news cset vset inve vdele vset vcom all y *set dz l / nz ctyp 1 csys 2 vcex nz mxv - 1 cset,,,loca 0.03 0 dz cset news flui view 1 1 1 plty ehid cplo Code:
vsty 4 4 csys 1 cdel all vdel all ccom all y v 1 v 9 1 vfill 1 9 vgen 5 10 1 9 1 0 1 / 8 vset all numb vert on vsty 4 4 vplo vgen 5 10 41 45 1 0 1 / 8 vset all vplo ctab 1 shell 2 c 1 2 12 11 cset,all cdisp,on,vert $vstyle,4,4,1 cplot cset all cgen 8 1 cset cset,all cplot cgen 4 10 cset cset,all numb cell on cplot cgen 5 10 25 28 1 cset,all cplot numb cell off zoom,off $replot pldi,off,all $pldi,on,box $wind,0,0,13.3,10 $replot csys 2 v 49 1 45 repl vfill 45 49 repl vfill 6 46 3 rp4 1 1 0 repl v 85 1 45 vfill 45 85 3 repl vfill 51 55 rp4 10 10 repl edge on repl vset all vmer vset cplot edge off numb all off repl vset all cset all *get maxv mxve vgen 4 maxv vset ,,, 0 90 cgen 4 maxv cset cset,all cplot zoom,off $replot numb all off edge on repl vset all vmer vset n edge on cplot edge off cdis off vert replot vset news edge repl vell 50 repl ccom all y vcom all y csys 2 v 301 1 0 0 vgen 32 1 301 301 1 0 90 / 8 vset news vran 301 400 numb vert on vplo cset all vset add edge vmer vset ,,,,,,,,, high dele vset news edge vplo cdis on vert cplo Code:
!!!!!!!!!!!!! EINGABEGROESSEN !!!!!!!!!!!!! ! Anzahl Zellen auf Umfang, immer durch 4 teilbar ! Am besten, so dass nc / 4 eine gerade Zahl ergibt *set nc 72 ! Anzahl Zellen in Randschicht (enthaelt auch die Uebergangsschicht) *set nr 6 ! Randschichtdicke, Geom. *set dr 10 ! Aussendurchmesser *set d1 50 ! Biasing Faktor *set bias 1.0 ! Cell type Nummer (Shell) fuer das o-grid *set ct1 5 ! lokales kart. Koordinatensystem fuer Erzeugung *set cs1 5 ! lokales zyl. Koordinatensystem fuer Erzeugung *set cs2 6 ! Definition der Koordinatensysteme !csys 2 !clocal 5 cyli,100,0,0,90,0,0 !csys 5 !cloc 7 cyli 0 0 0 -45 0 0 !csys 7 !cloc 5 cyli 0 0 0 0 0 0 !csys 5 !clocal 6 cart,0,0,0,-45,0,0 !csys 5 !!!!!!!!!!!!!!!! BERECHNUNGEN !!!!!!!!!!!!!!!!! ! Vorbereitung *set ddr dr / nr *set ddr -1 * ddr *set ro d1 / 2 *set ru ro - dr *get vmax mxvert *set vmax vmax ctab ct1 shell csys cs2 ! Randvertex Berechnungen *set vi vmax *set dphi 360 / nc *set phi -dphi *defi noex *set vi vi + 1 !*set phi phi + dphi v vi ro phi 0 *set phi phi + dphi *end *loop 1 nc vset news vran vmax + 1,vmax + nc,1 vgen,nr + 1,nc,vset,,,ddr,,,bias ! Cell - Erzeugung, Randschicht *get cmax mxcell *set offs nr * nc !*set co cmax + offs *set v1 vmax + 1 *defi noex c,v1,v1 + 1,v1 + 1 + nc,v1 + nc *set v1 v1 + 1 *end *loop 1 nc - 1 c,vmax + 1,vmax + nc + 1,vmax + nc + nc,vmax + nc cgen,nr,nc,cmax + 1,cmax + nc,1, ! Cell - Modifikation Randschicht, zur Kernerzeugung csys 1 *set offs nc * nr *set ofs2 nc / 4 *set v1 vmax + 1 + offs *defi noex vfill,v1,v1 + ofs2, *set v1 v1 + ofs2 *end *loop 1 3 vfill,v1, vmax + 1 + offs,ofs2 - 1,v1 + 1,1 ! Kernerzeugung *set v1 vmax + 1 + offs *set v2 v1 + ofs2 *set v3 v2 + ofs2 *set v4 v3 + ofs2 patch v1 v2 v3 v4 ofs2 ofs2 cset news type ct1 vset news cset vmer vset ! Glaetten !*get smax mxspl !*set sp1 smax + 1 !spl,sp1,vran,vmax + 1,vmax + nc,1 !splm,sp1,insert,vmax + nc,vmax + 1 !splgen,nr ,1,sp1,sp1,1,nc !vset news vlis v1 v2 v3 v4 !spls all !vset add spls !vsmo 6,20, !vell 1 |
January 21, 2012, 05:30 |
Nicholas
Rep Power: 17 |
Thanks for the scripts, I'll give those a go.
mesh, o mesh, proam, star cd |
ICEM CFD creating the grid of a Wind Turbine blade | Dan | CFX | 11 | June 1, 2012 15:11 |
creating r-z-theta grid | swati | FLUENT | 0 | March 1, 2005 03:17 |
GRID TO GRID INTERPOLATION in FLUENT | calogero | FLUENT | 3 | June 4, 2003 09:32 |
Combustion Convergence problems | Art Stretton | Phoenics | 5 | April 2, 2002 06:59 |
Troubles modelling flow through a grid | Hans Klaufus | CFX | 1 | June 28, 2000 17:43 |
