Home > Forums > Software User Forums > Siemens > STAR-CD
Fully developed flow
Old   December 16, 2011, 03:40
Default Fully developed flow
crevoise is on a distinguished road
I am computing a flow trough a pipe of diameter 50mm, and 700mm length. The mesh is around 300000 cells, with a finer mesh near the wall.
- On the inlet, my boundaries are the following: velocity: 25m/s and T=573K, turbulence intensity and length: 0.04 and 0.004.
- On the outlet, I apply a pressure boundary (piezo, zero grad for temperature)
- The walls are adiabatic, no slip.
- I am using K/epsi Hight Reynolds number scheme
- initial conditions: v:25m/s, T=573K
In steady state computation, I am reaching the convergence criteria (0.0001) around 260 iterations.
However, the velocity profile is not good, and I have no clue why(see residuals and velocity profile in attached).
If you have some idea about which mistake I have done, I will be glad to learn it. I guess the solution should be obvious for an experienced cfd, but...
Thanks a lot
crevoise is offline   Reply With Quote
Old   December 16, 2011, 04:14
k_k
Kailash
k_k is on a distinguished road
if your objective is to compute the fully developed turbulent velocity profile, use periodic boundaries on both ends of the pipe and specify the mass flow rate, turbulence conditions, pressure gradient across the pipe as inputs. you should get fully developed velocity profile on both ends of the pipe when convergence is reached.
k_k is offline   Reply With Quote
Old   December 16, 2011, 05:12
Thanks for your reply and the tip. I will try it.
However, my aim is to get a fully developed flow before starting some injection and reactions. Thus, my scalars will not have to be equal on the two boundaries faces, which is problematic in the idea of cyclic boundaries.
I can still first compute the fully developed flow with cyclic boundaries; and for the injection, restart the computation from the developed field, with different boundary conditions.
In the idea, I wanted to avoid a restart, so then, do not use a cyclic boundary. Do you think it is possible, or is it just a loss of time from my side to fight with this?
Thank you.
Old   December 20, 2011, 09:50
Hello again,
As advised k_k, I am running the simulation with cyclic boundaries.
On the inlet cyclic boundary, I am setting an inlet flow of 0.03kg/s, with a bulk temperature of 573.15K. On the inlet, I let the cyclic boundary with an 'all match' option.
My aim is to get a fully developed flow, with 573.15K and 25m/s, to match a case made on a 1D model (on the 1D model, the starting flow is already a fully developed flow, while StarCD gives a plug flow on the inlet)
So far, I am getting the fully developed flow, but with an average inlet temperature of 585K and an average inlet velocity of 26m/s.
My question is about the temperature: while setting a bulk temperature to 573.15K, I would have expected to get a 573.15K on my inlet as a result of the computation. So how to explain the 585K?
Thank you for your light on this point.
Old   April 28, 2017, 02:06
Birsen
birsenakin is on a distinguished road
Thanks a lot
how can I get this digram? I calculated for impinging jet Re=23000 amd I used k_omega model but I coudnt get fully developed turbulent kinetik energy. Also , I created geometry 3D and I gave plane to show mesh 2D . but my prof. I have to cread 2D how can I do? I convert 2D for region byt It gave me error. I coudnt run. ( I dont have time to this HW I need help I am new user for Star CC+ I watch all tutorais but to apply somthing hard.
please can you help me someone.
birsenakin is offline   Reply With Quote
on fully developed duct flow yfyap Main CFD Forum 6 November 7, 2012 09:59
Fully Developed Flow in Star-cd SMM STAR-CD 0 September 5, 2011 22:08
Fully developed flow profile icfd Main CFD Forum 3 May 20, 2009 22:21
udf for 3D laminar fully developed flow salman FLUENT 0 November 9, 2006 21:45
Fully developed flow Yap Wen Jiun Main CFD Forum 1 June 12, 2001 21:23
