Pressure difference after adding injectors in Prostar |
December 15, 2011, 07:35 |
Rep Power: 15 |
Hi
I need ur help i have simulated a moving chamber with it valves , using prostar after i simulate i have good pressure values (maximum pressure at tdc =45bar) after changing it to lagrangian multiphase and adding the injectors i have a pressure difference of 13bar at the same point do any one knows why ?? (fuel ration have been added in prostar option spraywithatomazation all the other options have been add in prostar ) do you have idea why there is a big difference betwwen the two simulations thxs alot aziz |
May 3, 2018, 05:19 |
moving mesh
subash
Rep Power: 9 |
How to move piston and valves in prostar, it shows cell deactivation error every time i try to deactivate cell using events file. Is there any procedure before deactivating a cell like moving grid commands or detaching the cell from the simulation. It would be very helpful if you point my errors.
Thank you..... Subash |
August 3, 2018, 16:40 |
Rep Power: 8 |
@Subash why are you trying this in prostar? Do you have access to es-ice?
August 5, 2018, 13:16 |
About Prostar
subash
Rep Power: 9 |
I have access to es-ice but I wanna know how to create a geometry and mesh it in prostar and also give event files to moving piston inside a cylinder.
August 5, 2018, 13:42 |
Rep Power: 8 |
Hi Subash, get in touch with your support engineers. They should be able to help you out.
How to read pressure at discrete points | paka | OpenFOAM | 16 | April 28, 2020 07:26 |
Pressure Rise Error | emueller | CFX | 0 | May 5, 2009 11:08 |
Difference in pressure drop results | To all fluent users need help pls | FLUENT | 4 | May 30, 2007 04:31 |
Difference in pressure drop results | al-jasim | FLUENT | 0 | May 28, 2007 09:54 |
Hydrostatic pressure in 2-phase flow modeling (long) | DS & HB | Main CFD Forum | 0 | January 8, 2000 15:00 |
