Home > Forums > Software User Forums > Siemens > STAR-CD
using K-W models for wind simulation around tall building
Old   March 13, 2010, 08:15
Exclamation How to use K-W models for wind simulation around tall building??/
Salman Najm
waisprince is on a distinguished road
Hi everyone,
I am carrying out wind flow simulation around tall building as part of my dissertation. I have used K-E (k-epsilon) model it looks o.k. but when i tried to use K-W model the pressure counter goes funny. I did not put any values for the Box Omega(rpm)_____ in the "Define the boundary conditions tab" and left the default value o. What values could i use as a rough guide, or leaving it as a default value should be o.k.
For the K-E i used k=0.025 and E=0.07 as defined in a similar simulation as mine, in the star-cd userguide.
Pne last thing, how do I find the errors of each simulation? i mean how do I compare the k-E and K-W model simulation for the same conditions and show that one is more accurate then the other.
If someone can guide me in the right direction that will be much appreciated........ Tanx in Advance..........
Last edited by waisprince; March 13, 2010 at 08:45. Reason: To make it sound like a question
waisprince is offline   Reply With Quote
W are the job opportunities in Building simulation suavi Main CFD Forum 3 October 4, 2007 14:49
Building Simulation Apostolos Main CFD Forum 1 October 14, 2005 09:02
Fire simulation using FDS from NIST Jens Main CFD Forum 1 January 22, 2004 02:53
Large Eddy simulation Andreas Hauser Main CFD Forum 1 May 20, 2000 21:33
3-D Contaminant Dispersal Simulation Apple L S Chan Main CFD Forum 1 December 23, 1998 11:06
