Home > Forums > Software User Forums > Siemens > STAR-CD
Can STAR-CD solve this coupling problem
Old   August 5, 2009, 02:57
Default Can STAR-CD solve this coupling problem
wu
lilyshining is on a distinguished road
Problem: gas flows in a vibrating pipe.
I want analyse the effect of the vibration of pipe on the gas flow
CAN Star -CD do it?
lilyshining is offline   Reply With Quote
Old   August 5, 2009, 23:41
Jiashing Liu
anunu is on a distinguished road
The morpher function is able to model the boundary motion. In the Star-CD's user guild, you can find the help about the morpher.
Best
Anunu
anunu is offline   Reply With Quote
Old   August 6, 2009, 12:37
Default newxyz
Mika Nuutinen
manuutin is on a distinguished road
you can model mesh motion with newxyz.f if your mesh nodes and cells are numbered in some sensible order (cartesian i,j,k or otherwise that makes it easy to determine position according to cell nad vertex numbers. For example you have cartesion square pipe, you can easily move the vertices e.g. sinusoidally in z-direction according to the position in x-dir.
manuutin is offline   Reply With Quote
Old   August 6, 2009, 19:36
wu
thx for your reply. i will try it
Please help with star run problem usker Siemens 3 July 11, 2007 03:48
error in star ccm+ unsteady problem Yue Siemens 1 April 2, 2007 11:15
Negative volume problem in Two-way FSI coupling fred CFX 3 August 16, 2006 10:03
Fluid-structure coupling problem bluebird Main CFD Forum 4 January 25, 2003 10:04
Fluid-structure coupling problem bluebird CFX 1 January 17, 2003 05:46
