Giovanni Centorame
Rep Power: 0 ![]() |
i'm studying the combustion of a small diesel 2 stroke engine for APU usage , for my thesis project. I'm using the ECFM3Z compression model, closed cycle, the engine is operating at 5000rpm, phi 0,75; I notice in spd01 that mass burnt starts to decrease in the end of combustion, when almost the fuel is burnt, and at the same time the fuel starts to increase, like there's new fuel in the chamber from nowere. Actual time step is 0,2CA until the injection begins, then 0,1CA during injection/combustion,and again 0,2CA from 40CA ATDC to the end ( exhaust port opening). Polymesh size is 1mm. I tried to reduce mesh size, reduce the time step ( 0.05CA) and under relaxing pressure ( o,4) and additional scalars to 0,8 but the problem still remains. What can i do? |
Rep Power: 6 ![]() |
Have you already solved the issue you were facing here?
Giovanni Centorame
Alright, thanks for replying. Most likely ECFM-3Z wasn't malfunctioning though. There must have been a setup error or inconsistency.
Mass imbalance problem in multiphase water and steam CFX case | Antech | CFX | 1 | October 26, 2020 04:03 |
Supersonic jet (Ma approx 5) global mass balance problem | Lonewolf_Mcquade | STAR-CCM+ | 1 | August 15, 2019 14:48 |
Defining a mass production source in a 2D problem | R.Velayati | Fluent UDF and Scheme Programming | 1 | July 3, 2019 23:55 |
Mass Flow from expression problem | Zigec | FLUENT | 1 | May 23, 2019 14:14 |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
